Old 12-10-2009, 09:35 PM   #1
pimpin88
pimpin88 is on a distinguished road
1996 SL
Default car idles high, 2000 rpm idle
Finally got the car started after I fixed the oil pressure issue, but now I have another issue.
The car runs at 2000 rpm without touching the gas. This is a 2000 SL1 with a motor from a 2001 SL1. I replaced the intake manifold gasket before installing the motor and torqued everything correctly. Swapped over a known good TPS. What else would cause a high idle, a bad IAC?
Thanks all!
Add to pimpin88's Reputation
Rate the quality of this post and help pimpin88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pimpin88 is offline   Reply With Quote
Old 12-10-2009, 10:44 PM   #2
Default Re: car idles high, 2000 rpm idle
Failed IAC or the dreaded vacuum leak. Did you put all the hoses back on?
Old 12-10-2009, 10:47 PM   #3
aa4lr
aa4lr has a spectacular aura aboutaa4lr has a spectacular aura about
1995 SC1
ETCS and or ECTS connector failure can cause this. If the ECTS indicates a low temperature to the PCM, the PCM will enrichen the mixture and cause the idle to be way high.
I had this problem on my 95 SC1.
Bill Coleman
2001 Saturn SC2 Auto (3/13-...) "Yellow"
1999 Saturn SL2 Auto (11/09-...) "White"
1995 Saturn SC1 Manual (9/08-...) "Gold"
1994 Saturn SL1 Auto (7/94-1/04) 144,000 miles "Green"
Add to aa4lr's Reputation
Rate the quality of this post and help aa4lr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aa4lr is offline   Reply With Quote
Old 12-10-2009, 11:15 PM   #4
Britta92SC2
Britta92SC2 is on a distinguished road
Britta92SC2's Avatar
1992 SC2
this just happened to us, after a repair. pulled pcm b fuse for 10 min. reg idle returned(we were following directions from a member). it may not be a cure but it may help to point you in the direction of the repair
Marine Mom. Always Faithful.
Add to Britta92SC2's Reputation
Rate the quality of this post and help Britta92SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Britta92SC2 is offline   Reply With Quote
Old 12-10-2009, 11:34 PM   #5
Stuck throttle?
Old 12-10-2009, 11:55 PM   #6
Brake booster vacuum line not reinstalled. The fitting for it is on the intake near the power steering pump.
Add to ssicarman's Reputation
Old 12-11-2009, 02:20 AM   #7
rc1488
rc1488's Avatar
Originally Posted by oldnuc View Post
failed iac or the dreaded vacuum leak. Did you put all the hoses back on?
^^^^^^^^^+1.
Add to rc1488's Reputation
Old 12-11-2009, 06:49 PM   #8
pimpin88
1996 SL
Another one fixed!!!
Swapped the IAC and pulled the PCM B fuse for about 10 seconds. Not sure which of those fixed it, but one of them did. Idled right down and sits around 750-800 rpm.
Just gotta bleed the brakes, put the tires back on and take it for a test drive!
Idle/Throttle/ECTS/Radiator? - Engine Revving High/Idles funny. thawkth S-Series General 3 05-15-2009 12:54 AM
My 2002 Saturn SC1 idles at 2000 RPM while in park. There is also a knocking sound. travisj027 S-Series Tech 7 02-02-2009 11:43 PM
High RPM in idle sparelink S-Series Tech 4 07-11-2008 09:33 PM
Dies at Idle with No AC / Idles 400 RPM with AC. Runs Fine SVO4Turbo S-Series Tech 10 08-04-2007 01:13 PM
Car idles high dubsl2 S-Series General 21 10-26-2006 09:58 PM
