Old 11-27-2003, 06:33 PM   #1
Rear-Vue
Rear-Vue is on a distinguished road
Rear-Vue's Avatar
Dizzy %$@@#$*# no more lights.. HELP!
hey all i'm just going crazy..
i tried that making side corner lights blink thing.. didnt work out that well and i blew a few fuses, and other stuff. a nice pair of clear bulbs.. and other stuff.. grrr
anyways my final result is. had to go back to my yellow bulbs. for front. and i dont have any interior lights anymore. my dome lights works and thats about it.. i think my sigarette works not sure.. i know theirs power to the sigarette lighter because my neons are still going on. but my dash is dead. no lights at all.
same with my turn signals.....
so all you saturn nutz out their HELp mee. figure this one out. plzzz..
http://www.saturnfans.com/forums/sho...&threadid=4576
Add to Rear-Vue's Reputation
Rate the quality of this post and help Rear-Vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rear-Vue is offline
Old 11-27-2003, 07:23 PM   #2
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
Sounds like some other fuses may be blown. I would put everything back the way it was and check all fuses. Then take it from there.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Old 11-27-2003, 08:28 PM   #3
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
If the dash illumination doesn't work, then odds are that your parking lights are also inoperative, as they are on the same circuit. Check the "park" fuse, and if it blows as soon as you replace it, remove the wiring mods and start over.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 11-27-2003, 09:14 PM   #4
Rear-Vue
Rear-Vue's Avatar
Default
with my remote car stater my lights do go on, when i start it manually they dont go on
Rear-Vue is offline
Old 11-28-2003, 12:50 AM   #5
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
Default
Sex should be like driving a honda...Slow, obscene and loud enough for the neighbors to hear !
ROFLMAO That has to be the best crack about a Honda I have ever heard.
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline
Old 11-28-2003, 10:06 AM   #6
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
still sounds like a blown fuse...
Old 11-28-2003, 12:28 PM   #7
Rear-Vue
Rear-Vue's Avatar
Default
yah i went fuse hunting i blew the park (ty applefool) and some other ones, turn signal, and some others ones not sure what they did besides break.. hehe
but its all working again just down 2 nice apc clear corner white bulbs and 2 apc turn signal bulbs.. 20 bux down the drain.
Rear-Vue is offline
Old 11-28-2003, 02:36 PM   #8
guardm
guardm is on a distinguished road
guardm's Avatar
Default
I would check that there are no exposed wires shrting to ground. then make certain that all your connections are pos. neg. as require by using a meter. If all appears ok, then you probably wired something wrong that blowing a fuse. I don't know the wire colors but all you should need is a relay and some wire. What you are trying to do is a relay trick that is used in many cars as an OEM feature.
Add to guardm's Reputation
Rate the quality of this post and help guardm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guardm is offline
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 03:33 PM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 09:40 PM
2006 Vue AWD Radio Lights and Dash Lights Problem molinee Vue Tech 4 04-11-2008 04:56 PM
2002 VUE AWD - Lights, lights, lights newpov Vue General 0 02-09-2007 01:23 PM
2003 Ion Tail Lights & Cluster Lights Out ticklescat Ion General 3 12-31-2005 05:13 PM
