Closed Thread
Old 03-01-2001, 07:55 PM   #1
avni_01SL2
avni_01SL2 is on a distinguished road
Default "Smart" transmission
I;ve been hearing on and off about the Automatic Transmission "learning". Is there some sort of adaptive programming in the shifting algorithm? Does anyone have any information on this? Very curious. What sorts of things does it adjust for, and in what way?
Thanks
Avni
Add to avni_01SL2's Reputation
Rate the quality of this post and help avni_01SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
avni_01SL2 is offline
Old 03-01-2001, 11:36 PM   #2
SCDYNE
SCDYNE is on a distinguished road
SCDYNE's Avatar
2007 SKY
1997 SC2
Default
The Saturn Automotice transmission learns your shifting paterns and responds accordingly. It takes about 5000 miles for the transmission to fully adjust to your style of driving, but once it does, shifting is more percise and it doesn't shift back and forth as often. One of the traits of the intellegent transmission is to shift on hills to prevent a change in vehicle speed and sometimes slow the vehicle down if it's coasting...
That's all I remember about it and even that's probably wrong..
Add to SCDYNE's Reputation
Rate the quality of this post and help SCDYNE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SCDYNE is offline
Closed Thread
Battery draw, transmission slam and "Shift to D2" dtuuri S-Series Tech 3 03-15-2014 05:55 PM
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota Charlie General Saturn Discussion 20 02-25-2011 05:11 PM
2002 SL1 Transmission issues, "reverse slam", P0708 code, transmission range sensor mt_spiffy S-Series Tech 20 12-14-2009 03:17 PM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 10:14 PM
Transmission Drain plug hole "buggered up" roswell998 Miscellaneous Tech 4 11-24-2004 10:17 PM
