Old 07-18-2014, 02:11 PM   #1
Pac_Man_13
Pac_Man_13 is on a distinguished road
Default What is possibly causing this misfire??
96' Saturn SC1
Check engine light: P0304 : Cylinder 4 misfire
The car is also idling very high, the rpm's jump up and down and the temperature slowly rises to almost 3/4 when the car is stopped but running, the engine shakes when idling (Just changed the upper motor mount), it's also burning a lot of oil (more than normal). The car struggles up hills causing the check engine light to start blinking when the car downshifts.
Check engine light has been on for months, I can not find the root of this problem. Changed all the plugs and wires, changed both ignition modules, took the throttle body off cleaned it and the inside of the intake manifold, they were both covered in a layer of black soot. Also switched the throttle body gasket although the old one did not look very worn when I spayed brake cleaner between the throttle body and intake manifold with the car idling the idle dropped to around 900 RPMs (Usually idles at least 1300)
The only other option I haven't done yet is to change the intake manifold gasket. Does anyone think this is the problem? I've read it is a fairly time consuming job so I don't want to start if that is not going to fix the misfire. I have to take this car on a 1500 mile trip in a couple weeks, any suggestions are appreciated.
Pac_Man_13 is offline   Reply With Quote
Old 07-18-2014, 02:24 PM   #2
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Default Re: What is possibly causing this misfire??
I would start off with a compression test focusing in on cylinder 4.
CHECK YOUR OIL!
Old 07-18-2014, 03:33 PM   #3
Signmaster
It sounds to me like a second test would confirm or deny the vacuum leak at the gasket. It might not be the entire problem, but it certainly isn't going to help you find the other problems if they exist.
I really think you have have answered your own question in regards to the gasket.
Compression test wouldn't be a bad idea still, since your misfire seems to be fairly bad and you are burning lots of oil. Short of that swapping injectors to see if the misfire follow the cylinder or injector might be worth a shot.
Old 07-18-2014, 04:18 PM   #4
54packman
54packman will become famous soon enough
1998 SW2
2000 SC2
normally the intake gasket will cause a high idle as well though, would do a compression test and see what happens there,, maybe switch the plug wires between #1 and #4 coil towers and see if the problem moves to #1 cylinder..
54packman is offline   Reply With Quote
Old 07-18-2014, 07:54 PM   #5
Pac_Man_13, being a new member with an old car with a mystery problem, did anyone ask about your engine coolant temperature sensor? Search posts about it.
VCX NANO
Old 07-18-2014, 11:00 PM   #6
wingsauce7
wingsauce7 has a spectacular aura aboutwingsauce7 has a spectacular aura about
2000 SL1
Spray some starting fluid around the IM gasket with the car idling. If you have a leaky gasket, your rpms will increase drastically as the staring fluid gets sucked into any breaches.
2002 SL1 Manual 208,000 miles
2001 SL1 Manual 425,000 miles!! (original clutch)
2000 SL1 Manual 235,000 miles
wingsauce7 is offline   Reply With Quote
cylinder 4, high idle, intake manifold gasket, misfire, p0304
Random Misfire, and cylinders 2,4,6 misfire. Mitcheky Vue Tech 30 05-21-2015 12:20 AM
could my ngk plats be causing misfire 1sksc2 S-Series Tech 9 01-06-2013 04:52 PM
Oil Leak - What's causing it? Growser S-Series Tech 7 09-17-2008 04:28 PM
What is causing this? Yenko S-Series Tech 4 07-21-2008 08:07 AM
What MIGHT be causing my Cylinder 4 Misfire SaturnManiac S-Series Tech 11 07-06-2007 05:37 PM
