Old 04-14-2011, 07:14 PM   #1
handcannon44
handcannon44 is on a distinguished road
2000 SL1
Default went from p0301 to p0304
i have a 2000 SL1 had the faulty intake gasket problem causing misfire on cylinder 1 ( p0301 ). changed gasket everything was great after that for a month. Now i have missfire on cylinder 4! im stumped drove around all day yesterday just fine. Startedthis morning with ruff idle and almost immediate code.
compression is good all above 180
just replaced plugs and wires when i did the gasket and cleaned coil terminals at the same time did ohm test on coils checked out ok
fuel pressure was good dont remember the exect numbers but i know it was within peramiters at the the time i checked it about 2 months ago
handcannon44 is offline   Reply With Quote
Old 04-14-2011, 11:40 PM   #2
Default Re: went from p0301 to p0304
Check for vacuum leak or slightly open EGR valve.
Old 04-17-2011, 11:42 AM   #3
handcannon44
2000 SL1
no vacuum leak and cleaned egr still misfireing
Old 04-17-2011, 01:06 PM   #4
Cut up a can and block off the EGR ports. Use the EGR to hold it in place on top of the gasket and keep the EGR plugged in. If that does not show anything the next step is a compression test.
Old 04-17-2011, 01:26 PM   #5
handcannon44
2000 SL1
compression is good 195 ill try blocking of the egr next
sorry if this a dumb question - why would the egr only affect cylinder 4
should i try swapping the injector with another and see if the misfire moves
Old 04-17-2011, 02:43 PM   #6
Listen to the injectors when the engine is running, use a long screw driver. The EGR port in the intake is closest to #4. And #1 and #4 are on the same coil. So an ignition issue is not out of the question. Plugs, wires, coil, ICM are possible.
What brand wires and plugs?
I would swap the coils first, it is easier to do.
Old 04-17-2011, 03:21 PM   #7
handcannon44
2000 SL1
already swapped coils with no effect
i went ahead and swapped injectors i swapped 3 and 4 to see if the misfire moved. instead it went away completely. i drove it around for 45 min no codes pop up on scanner. could the injector have been stuck and removing it or releasing fuel pressure freed it up ? i did put in some injector clean when i filled it up last (its at half a tank now) could that have flushed something down the line?
it defiantly is not the first thing ive taken apart and put back together to have a problem mysteriously go away. im a little wary of its reliability now though.
thanks for your help ill just have to cross my fingers it doesnt do this again
Old 04-17-2011, 04:42 PM   #8
May have been a dirty electrical connection or possibly stuck pintle. Hard to tell. Just be glad it is fixed or isolated to injectors and associated wiring.
misfire, p0301, p0304
P0304 cyl 4 misfire detected 97sl2DOHCaut1.9 S-Series Tech 22 06-14-2011 02:34 PM
P0304 jaekl S-Series Tech 4 09-01-2010 08:25 AM
Need some help with ICM, code P0304 rfortier1796 L-Series Tech 3 08-23-2010 02:34 PM
P0304 has me confused? 3500srw S-Series Tech 11 06-24-2008 12:01 PM
P0304 Code (out of ideas) mike_245 S-Series Tech 13 03-13-2008 03:28 AM
