Old 02-05-2011, 04:37 PM   #1
mattachuz
mattachuz is on a distinguished road
mattachuz's Avatar
Default washer fluid low
was on my way home and the washer fluid was low from when i use it quite a bit, it would flash low when i would make a right turn, and then i got home and refilled it with straight water, and now the washer fluid low light is on all the time!? is there a reset button somewhere?
the water is to the brim of the washer fluid fill hole.
Matt
Add to mattachuz's Reputation
Rate the quality of this post and help mattachuz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattachuz is offline   Reply With Quote
Old 02-06-2011, 11:36 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: washer fluid low
Nope, no reset button, and since the light was flashing when the fluid was moving around before you filled it, sounds like the sensor is still working, so no idea how this could happen.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 02-06-2011, 04:50 PM   #3
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
2001 L-Series 2.2L Sedan
try pulling the sensor out and cleaning the surface up and check the connection.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Add to Robman's Reputation
Rate the quality of this post and help Robman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robman is offline   Reply With Quote
Old 02-07-2011, 03:32 AM   #4
mattachuz
mattachuz's Avatar
let the car sit for a few hours full of fluid and later on that night went out for a bit and the light finally went off.
Old 02-07-2011, 03:54 PM   #5
Robman
Robman's Avatar
the blue crud in the washer fluid will dry on the sensor after several occurrences of "running out" and that is where you get the low fluid light situation. the water may have removed it.
Rob
2001 Turbo L200
1997 F150 XLT
Do It Yourself
washer fluid doubleb99 Astra General 1 06-14-2010 09:28 PM
washer fluid My08Vue 2008 Vue 5 10-29-2008 03:35 PM
95 SL1 washer fluid problem deeray41 L-Series Tech 1 08-09-2007 08:34 PM
Washer Fluid. Dserge S-Series General 6 05-09-2007 10:28 PM
Odd-looking washer fluid karinhesed86 S-Series General 28 01-18-2006 11:14 PM
