Old 02-26-2021, 12:53 AM   #1
Simpleman
Simpleman is on a distinguished road
Dizzy 1999 sl2 saturn 5sp 238,000 miles
I have a 2000 SL2 Saturn 5 speed Dosch dual cam it currently has 238 thousand miles on it I was wondering what kind of power adders that I can do to it without completely destroying my motor even though it might not make it that much longer should I just put a new motor in it or just leave it like that me personally I was going to put a luk clutch kit along with a matching flywheel with cold air intake nickel spark plugs NGK wire sets new clutch linkage Master slave cylinder but also wanted to put a whole new motor in it but don't have really the money to spend like that so for a junkyard motor
Simpleman is offline   Reply With Quote
Old 02-26-2021, 09:57 AM   #2
onlinebiker
Default Re: 1999 sl2 saturn 5sp 238,000 miles
Trying to pump up an engine with a quarter million miles on it is a bit like a 95 year old guy scarfing down a handful of Viagra.
Sure - he' s going to have fun for a short time - but you can predict how it' s going to go for the old guy....
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2 auto
02 SL2 5 sp
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 02-26-2021, 11:07 AM   #3
Waiex191
Waiex191's Avatar
Quote of the year so far!
OP, check out https://forum.sixthsphere.com/. They do crazy stuff to Saturns there.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 02-26-2021, 02:36 PM   #4
Originally Posted by Simpleman View Post
. . . what kind of power adders that I can do to it without completely destroying my motor even though it might not make it that much longer. . . but don't have really the money to spend like that so for a junkyard motor
If this is your only car and you rely on it for work, school, or shopping, etc., you may want to re-think anything that affects its reliability.
There's a quote about cars being reliable, fast, cheap - pick any two. A stock Saturn S is cheap and reliable but not fast.
Other than CAI which it already has, those are maintenance items.
May as well call it now, I think that's a winner!
Also, taking notes for my 95th birthday present to myself
Old 02-27-2021, 11:35 AM   #5
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SL2
1995 SW2
A word of advice from somebody who's done it before: dont.
I have a 95 Sl2 with 150k, I started with a header and intake, then full exhaust, then cams, then megasquirt (aftermarket tuning), then turbo. Now the car is pretty unreliable, horrible on gas, and essentially a ticking time bomb.
So I ended up buying a 95 SW2 to daily drive since my Sl2 was unreliable and having issues.
The lesson here is that modifying a daily driver for more power will result in the need for a new daily driver.
I would keep driving your car, and look for another one to modify.
1994 Sl2 5spd First Car, Stock: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd: Retired Daily, Not Stock: 192,000
1998 Sl2 5spd: Family Car, Stock :135,000
1995 SW2 4spd: Daily, Stock: 91,000
Old 02-27-2021, 03:59 PM   #6
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Or you just need to know how far you can safely go. I feel like a NA deebs build would be pretty fun to do one day without much reliability loss since it uses all OEM parts. Its not that much more power, but if you are going to be rebulbing a twin cam it's really not that much extra work.
Once you get into forced induction, a standalone ECU, or both, that's probably when reliable daily driver territory ends.
97 SL2, auto, 123K miles
Old 02-27-2021, 04:49 PM   #7
Waiex191
Waiex191's Avatar
I recommend this:
http://www.saturnfans.com/forums/sho...d.php?t=215499
Bryan Cotton
1999 SW2 Won't START 75,867 miles MaggieMay007 S-Series Tech 8 01-29-2019 11:02 PM
1999 SW2 Won't START 75,867 miles MaggieMay007 S-Series Tech 1 01-29-2019 02:31 PM
1999 Saturn SC2 manual how many miles it will drive only on battery vikasevan S-Series Tech 8 03-04-2017 11:55 AM
1999 SL2 26,000 miles dnwoody S-Series General 11 11-13-2012 03:02 PM
1999 SL2 ~128,000 Miles - heater not warming car 2002SaturnMan S-Series Tech 11 01-06-2010 03:35 PM
