Old 11-24-2005, 02:24 PM   #1
95c2
95c2 is on a distinguished road
1995
Default Upper strut MOUNTS????
do i need these for my lowering kit? I hope to get the intrax lowering springs with at 1.7 front and 1.6 rear with KYB'S and a 15-16" rim and falken 512 series tires if that matters. I also plan to "DIY" this project. DO i need theM or does anyone have any opinoins on my setup?
Add to 95c2's Reputation
Rate the quality of this post and help 95c2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
95c2 is offline   Reply With Quote
Old 11-24-2005, 02:43 PM   #2
LowSC2
LowSC2 is on a distinguished road
LowSC2's Avatar
1999 SC1
1991 SL2
Default Re: Upper strut MOUNTS????
Unless they're making a grinding noise when you turn, I'd say you're ok to keep the originals.
Jeff Silva ~ 91 SL2 - 11.809 @ 116.488mph
•Chilton & Haynes manuals are junk
•Changing the ECTS doesn't fix everything
Add to LowSC2's Reputation
Rate the quality of this post and help LowSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LowSC2 is offline   Reply With Quote
Old 11-25-2005, 12:59 AM   #3
geartooth94
geartooth94's Avatar
or if you are "clunking" on minor bumps in the road @ 25-35 mph, then do so also. thats what mine sounded like before they were replaced.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 11-25-2005, 02:28 AM   #4
wolfman
wolfman's Avatar
Lowering also generally changes the spring rate and stress on the upper mounts. Better to spend the extra $$$ now then have to take everything back apart in a few months.
Add to wolfman's Reputation
Old 11-25-2005, 10:58 AM   #5
95c2
1995
so about how much will these mounts cost and what brand should i get. I will also be doing this myself if i have to change them out.
Old 11-25-2005, 11:46 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
I'd get the OE ones from Saturn. Be careful when you remove the front ones so the ball bearings don't fall out. The rear ones don't have that problem.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Front upper strut mounts & link kits replacement marmaduke L-Series Tech 15 05-13-2011 10:50 AM
Gabriel Front Upper Strut Mounts - Crap cris_thomas S-Series Tech 1 11-23-2008 02:33 PM
Redesigned Upper Engine Mounts? occamsrezr S-Series General 2 04-21-2006 08:52 AM
KYB upper strut mounts Twin_Cam Miscellaneous Tech 7 09-29-2004 02:18 PM
New upper engine mounts, bolts, nuts David 93 SL2m S-Series Tech 15 10-04-2002 05:14 PM
