Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 05-10-2015, 01:29 AM   #1
zeissheadreggie
zeissheadreggie is on a distinguished road
Location: East point, GA(3 clicks outside of the atlanta city limits)
2005 VUE Red Line
2000 L-Series 3.0L Sedan
Default Can't remove the Key from the Ignition Switch
Hey everybody! I know I'm not the only one to have experienced A key stuck in the ignition switch. The key is stuck in the accessory position, and the radio is running, so I've simply turned the radio off, locked the car with the key fob, and said a prayer that my car will be in the driveway in the morning. Any suggestions would be greatly appreciated.
live fast, die young, and leave clean underwear!!
Add to zeissheadreggie's Reputation
Rate the quality of this post and help zeissheadreggie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zeissheadreggie is offline   Reply With Quote
Old 05-11-2015, 04:57 PM   #2
flyingj
flyingj will become famous soon enoughflyingj will become famous soon enough
flyingj's Avatar
Default Re: Can't remove the Key from the Ignition Switch
Sounds like the ignition switch locked up because of an old/worn key. Had this happen in my L, and it required a new ignition switch (and key but was keyed to match the doors).
2001 L-200 2.2l
DOB: 05/08/01 Owned: 07/01/07 to 10/30/18
2006 Vue 3.5L AWD Mileage: 145,000
DOB: 08/24/05 Date Acquired: 12/15/06
2019 GMC Acadia (aka Saturn Outlook)
Add to flyingj's Reputation
Rate the quality of this post and help flyingj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyingj is offline   Reply With Quote
Old 07-14-2015, 08:35 PM   #3
Warden1
Warden1 is on a distinguished road
Had same issue, GM has extended warranty on ignition switches and will replace at no cost to owner.
Add to Warden1's Reputation
Rate the quality of this post and help Warden1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Warden1 is offline   Reply With Quote
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 04:30 PM
Ignition Cylinder or Ignition Switch silverslp S-Series Tech 1 01-05-2015 11:09 AM
Ignition Switch or neutral safety switch? MNGuy S-Series Tech 16 05-22-2014 12:12 PM
Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission infinitezero Ion Tech 5 11-25-2011 05:47 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 02:09 AM
