Old 11-10-2019, 05:02 PM   #1
DCAlden
DCAlden is on a distinguished road
2008 Astra XR
Default Need Exhaust System Diagram - 2008 XR Door
Hi! I am the new owner of a 2008 Astra XR 4 door hatchback which is in great shape except the exhaust is a little loud. From crawling under the car I can see that the flex pipe is probably leaking but I canít see the rest of the system until I can get it up on a hoist.
It would really help if anyone knows where I can get a diagram of the complete exhaust system so I can start to identify the parts that I am going to need. I found some reasonably priced parts new on eBay. Are there better places to source parts?
Is this a job that a reasonably competent diy guy can do in the driveway or are there difficulties that would require a shop to replace the whole system?
Thanks!
Add to DCAlden's Reputation
Rate the quality of this post and help DCAlden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DCAlden is offline   Reply With Quote
Old 11-10-2019, 07:16 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: Need Exhaust System Diagram - 2008 XR Door
One issue with working DIY with exhaust is that due to the high heat studs or bolts have a tendency to snap off.
Could be leaking at the flange gasket or the flex pipe. It may be possible to cut out the flex pipe and clamp or weld in a new one depending on if there is room and rest of the pipe is in good shape.
Parts diagram:
https://www.gmpartsonline.net/v-2008...ust-components
Old 11-10-2019, 08:14 PM   #3
AstraFasta
Flex pipe is a frequent failure part on the Astra. Of course, there are other exhaust possibilities but that is by far the most frequent. You can do a search here for more info.
That pipe suffers a lot of pressure and stress, so I would not DIY repair. A local independent shop can weld on a new flex pipe for under $200 or less, depending on your location.
Old 11-11-2019, 01:17 PM   #4
DCAlden
2008 Astra XR
Thanks for the link to the parts diagram and the suggestion about getting a new flex pipe welded in. Very helpful!
2008 VUE seat wiring diagram Swag Vue Tech 2 10-21-2018 09:13 AM
Request for a Saturn vue 2008 radio wiring diagram Peter0321 Vue General 3 11-24-2014 05:51 PM
Anyone have an AC System Line Diagram for a L300? thepat L-Series Tech 2 06-30-2013 06:55 PM
wiring diagram Audio system 2003 Vue hawthorne Vue Tech 6 04-21-2013 09:52 AM
95 SC2 Exhaust System Diagram? Moist S-Series Mods 31 05-16-2007 02:28 PM
