Old 05-20-2019, 10:06 PM   #1
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default need a super window cleaner for lovebugs
hi sages- rode down florida turnpike yesterday.massive lovebug attacks on windshield at 70 mph slathered all over it and baked on at 90degrees. no success with windex. any ideas? is a single edge sharp razor the answer. car wash shysters want $35. thanks tons bob f
Add to rfisher's Reputation
Rate the quality of this post and help rfisher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-20-2019, 10:09 PM   #2
toggenburg
toggenburg's Avatar
Default Re: need a super window cleaner for lovebugs
Soap it up, and use one of those mesh covered sponges like for dishes. It should come off with elbow grease.
Old 05-21-2019, 12:11 AM   #3
Rj 2000 LS2
Rj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the rough
2000 L-Series 3.0L Sedan
Windex with a razor blade and then super fine steel wool.
Add to Rj 2000 LS2's Reputation
Rate the quality of this post and help Rj 2000 LS2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-21-2019, 08:42 AM   #4
rfisher
hi sages- windex is generally good for cleaning surfaces in cars but it failed this time. the residue is like trying to remove dried paint. used very bad words, even slandered the muthas of lovebugs. afraid I will now be disqualified from the yacht and country club. has anybody used lately this product called invisible glass or is it a fake mouse milk. fear steel wool is too risky- permanent scratches to glass. sounds like a job for superman. thanks tons bob f
Old 05-21-2019, 09:11 AM   #5
Rj 2000 LS2
Triple 000 steel wool will clean your windows to like new condition. It doesn't scratch, it polishes and removes any and all wear. You just need to first use Windex (as a media to keep the bugs from entering yer breathing hole) with a straight razor. Not the type that you shave with, I assume you shave. You can buy razor sharp utility blades which you can hold in your hand. It will take time, but your windows will thank you. If you were to use steel wool first, it would not clean the baked on bug remnants!
I use super fine steel wool on my wife's Saturn and believe me... if I scratched up those windows I would be in the dog house for life! I use an entire steel wool pad on dry glass. It works, trust me!
Old 05-21-2019, 11:19 AM   #6
focusofheart
focusofheart has a spectacular aura aboutfocusofheart has a spectacular aura aboutfocusofheart has a spectacular aura about
Try WD-40? I used it on my windows after having my tint removed and it took off the traces of glue using a straight edge. It might work on bugs too.
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-21-2019, 11:35 AM   #7
I've used 000 steel wool and its perfectly fine. In combination with plain water, soapy water, Windex, WD40, windshield washer fluid or any other type of lube, extra fine steel wool or a new box cutter blade will work to scrape off anything glued to windshields. With fine steel wool, bits are left everywhere so a rinse with the garden hose should wash away everything clean.
Old 05-22-2019, 08:21 AM   #8
rfisher
hi sages- thanks tons for the info. where to do you get super fine OOO steel wool? ace hardware? home depot? will try the WD 40. yesterday picked up gallon of windex special bug juice remover fluid for windshield washer. seems to be a new product. will keep you posted. thanks bob f
Old 05-22-2019, 10:46 AM   #9
Dsaturn
Dsaturn is just really niceDsaturn is just really niceDsaturn is just really niceDsaturn is just really nice
2001 L-Series 2.2L Sedan
Any place that sells paint and paint products should have 000 wool.
Add to Dsaturn's Reputation
Rate the quality of this post and help Dsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dsaturn is offline   Reply With Quote
Old 05-22-2019, 10:09 PM   #10
rfisher
hi sages- hit paydirt. solved problem. used a combination of a new single edge razor blade, a clean rag dampened with windex bug remover windshield washer fluid and OOO extra fine steel wool, alternating back and forth . got all the slop off. florida heat baked it on like paint. like it when the forgotten man wins and beats the shysters. regards bob f
Old 06-04-2019, 02:58 PM   #11
Russet
2002 L-Series 3.0L Sedan
Not the brightest move here roadman. Oil leaves stain.
Add to Russet's Reputation
Old 06-04-2019, 03:39 PM   #12
Russet
I use RainX winter formula with bug wash this gives the windshield clean and gets rid of bug stains. This works when on the go if your at home soaking the windshield down and using a auto cleaning brush goes along way to remove the bug splats. RainX isn't cheap but if you want good cleaning don't cheap out on keeping the windshield visible.
Old 06-04-2019, 05:09 PM   #13
focusofheart
To be sure I was not causing a problem, I researched out my suggestion of using WD-40 prior to posting the comment, even though I had used it myself on my car windows without harm. I also used a simple solution of Fels-Naptha to get off the residue which was left rather than use a detergent.
Dealer pushing injector cleaner and AC cleaner LotusLord Vue General 19 07-01-2008 01:48 PM
Prestone Super Flush vs. Super Radiator Cleaner The Critic S-Series Tech 8 12-07-2006 10:39 PM
GM Top Engine Cleaner Vs. Piston and Ring Cleaner Petey S-Series Tech 5 09-09-2005 12:56 PM
New window Cleaner. OKCION3 Ion General 23 02-03-2004 11:18 PM
Dang Lovebugs! sps SOHC General Saturn Discussion 26 05-15-2003 01:35 AM
