Old 05-20-2019, 09:12 AM   #1
unpolire
unpolire is on a distinguished road
Default 2003 3.0 V-6, rebuild or replace?
After throwing many thousands at an auction-purchased Vue that was not properly maintained, I now have to deal with blown head gaskets at 155,000 miles. The labor cost is high to do a head job, so I am considering replacing the engine with another or rebuilding the current engine, if it can be successfully done. Only the long block is original as all other parts are new or very recent. I know that some alloy engines cannot be successfully rebuilt. Is the 2002-2003 3.0 V-6 capable of being professionally rebuilt? Used engines that I see for sale are from 96,000-250,000+ miles!
Add to unpolire's Reputation
Rate the quality of this post and help unpolire reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unpolire is offline   Reply With Quote
Old 05-20-2019, 09:17 AM   #2
Cavell
2004 VUE 3.5L
Default Re: 2003 3.0 V-6, rebuild or replace?
you spent thousands on a 16yr old vue at auction?
Add to Cavell's Reputation
Old 05-20-2019, 10:58 AM   #3
Cavell
2004 VUE 3.5L
replying about money is not an answer. are you going to do the work yourself? pulling the heads is not real hard. i got lucky last yr and picked up a botched 3.0 timing belt vue that had a new exhaust. which unbolted easily from manifolds. though i think even an old rusty exhaust will drop ok. you should also change the timing belt and tensioners which is another $100 or more in parts. you must really want to get this thing going. i have a similar vue lined up but am not crazy about getting it. even for $200
Old 05-20-2019, 12:31 PM   #4
unpolire
I have spent thousands since auction purchase in replacing all the external components like the crank position sensor, ignition coil packs, water pump, timing belt and tensioner, starter, alternator, battery, air conditioning compressor and hoses, gaskets, etc. Only the heads and pan have not come off and are original. My question regards the integrity of the 3.0 V-6 fitted to the first-year Vue. Is it capable of being rebuilt? Many all-alloy engines, especially some BMW models, are throw away engines.
Old 05-20-2019, 02:25 PM   #5
Cavell
2004 VUE 3.5L
been told its a solid motor. i replaced bent valves and did not refurb the head. no machining. and it ran fine. but i did not have an overheating issue to start with. i did get a puff of smoke on startup though. was it rings? or guides? i had it for several weeks and the startup smoke never got better
Old 05-20-2019, 07:23 PM   #6
unpolire
Thank you! The answer I was seeking. I'll now call a machine shop for a quote.
Old 05-20-2019, 07:35 PM   #7
unpolire
$1,695 to rebuild with a 12,000 mile/12-month warranty. Have to bring in just the block and heads.
Old 05-21-2019, 03:25 PM   #8
Cavell
2004 VUE 3.5L
thats a vague statement, just block and heads. so much more as you know. i assume you mean the crank, rods, pistons are involved? you dont bring in a bare block. they are going to bore/hone cyls, and replace pistons and resize rods? an OHC motor may not even have the cam sprockets. timing belt, and tensioners and sprockets and timing cover will be included? they will check and inspect cams for lobe wear? and replace lifters? which cost $25each and there are 24 total for $600 just for lifters.
Old 05-21-2019, 05:56 PM   #9
RobertGary1
1996 SC2
Pulling the head is quicker than changing out the engine. Either your own time or someone's hourly labor rate.
The engine is still low mileage.
-Robert
RobertGary1 is online now   Reply With Quote
rebuild or replace? SBXLI93 S-Series General 2 09-27-2009 09:26 PM
Rebuild, or replace, new or used? 1997sw1 S-Series Tech 24 09-13-2009 11:16 AM
2003 VUE 2.2L AWD - rebuild or replace VTI? kim_lombard Vue General 6 06-10-2009 08:15 AM
rebuild or replace? gmelton S-Series Tech 10 04-24-2005 01:17 AM
Rebuild or Replace Hodado S-Series Tech 20 07-26-2001 03:40 PM
