Old 09-12-2015, 07:46 PM   #1
lefthookright
lefthookright is on a distinguished road
Default Can't remove lug nut studs in 2005 Saturn Ion
Hi all. I am trying to replace bent lug nuts on a 2005 Saturn Ion. The problem is there is no "hole" to push the backs of the studs through. I've rotated it 360 degrees around and there is no way to remove these studs that I can see. Do I have to remove the hub to do this repair? If so how do I remove the hub?
Add to lefthookright's Reputation
Rate the quality of this post and help lefthookright reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lefthookright is offline   Reply With Quote
Old 09-12-2015, 08:32 PM   #2
Default Re: Can't remove lug nut studs in 2005 Saturn Ion
Does this help?
File Type: pdf Wheel Stud Replacement 4-Stud Pattern.pdf (106.3 KB, 8 views)
Old 09-16-2015, 02:19 PM   #3
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
Front or rear?
afaik, the fronts, to remove, they are pushed backwards and exit from the back of the hub.
hub removal is recommended for changing stubs, but its doable, but difficult, without removal.
to remove the hub, there are 3 mounting bolts on the back side to unmounts, and then you have to remove the axle nut in the center.
when removing the axle nut, count how many full rotations it took to remove it, and then use that many rotations to reinstall it.
If I remember right, the 3 mount bolts are 12mm, and the axle nut is 29mm.
you will also need a jaw puller to pull the hub off the axle.
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevin.st56 is offline   Reply With Quote
Old 09-16-2015, 09:49 PM   #4
2006 ion2
2007 ION-2 Sedan
I always do it with a mallet or sledge, works just fine
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 09-18-2015, 05:53 PM   #5
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
I thought of that too, but wasn't sure if going Clarkson would have been a good idea
03 ion-2 Sedan 5sp
♕KCCO
Old 09-18-2015, 10:52 PM   #6
2006 ion2
2007 ION-2 Sedan
In this case going full blown clarkson is acceptable. I've done 3 this way. You obviously have to be careful not to obliterate the threads, but they're pretty well protected.
2007 Saturn Ion 2
Old 09-21-2015, 10:58 AM   #7
Tyguyhihi
Tyguyhihi is on a distinguished road
2004 ION-3 Quad Coupe
Note that going Clarkson on it will shock-load the bearings. It's not going to ruin them, but will likely shorten their expected life.
I've done it, but would recommend bracing the disc with an 'anvil' of sorts (anything heavy that will absorb some of the shock).
Add to Tyguyhihi's Reputation
Rate the quality of this post and help Tyguyhihi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tyguyhihi is offline   Reply With Quote
Old 09-21-2015, 02:28 PM   #8
2006 ion2
2007 ION-2 Sedan
If you're reusing the bearing, i would definitely recommend using a 2x4 or 4x4 between the sledge and axle. Also, always only use as much force as necessary, and no more.
2007 Saturn Ion 2
Old 09-23-2015, 02:39 PM   #9
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
it doesn't take much to hammer it out.
I think I may have used a hammer to remove broken studs, but I tapped it out.
I didn't do a whole single swing at it like Clarkson would lol
if a hammer isn't available (why would you not have one?) then a C clamp would work also.
03 ion-2 Sedan 5sp
♕KCCO
Old 11-14-2015, 09:43 PM   #10
kgiri247
kgiri247 is on a distinguished road
I struggled with this one today. Got the broken stud out but not enough clearance to get the new one in! Reading through the pdf posted it looks like i can loosen the 3 15mm bolts without removing the hub to get 1/4" of clearance? Any one else have any recommendations or does the hub have to be removed? Had the oil changed and tires rotated 3 months ago at the dealer. They must have broken it off and never said anything. Hopefully I can just get them to fix it.
Add to kgiri247's Reputation
Rate the quality of this post and help kgiri247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kgiri247 is offline   Reply With Quote
Old 11-15-2015, 12:38 AM   #11
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
Call the Hulk ......... he always takes care of hard to take off nuts and bolts.
The more you piss him off the quicker the job gets done and the less labor you pay at the repair shop!!!!
Cheers,
Sam
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
How to remove engine 2005 ion ronjules Ion General 1 04-06-2015 05:12 PM
1996 Saturn Sc1 engine mount studs ladyantiantain S-Series Tech 2 12-20-2012 05:23 PM
starter studs -- anyone here ever had a chance to convert their bolts to studs... adventureoflink S-Series Tech 8 06-01-2011 10:04 AM
how do you remove seat covers in a 2005 Vue? (installing video headrests) slue Vue General 5 08-22-2010 12:21 PM
which studs remove the Bus Plate on the Valve body? slowroller S-Series Tech 2 07-25-2006 11:17 AM
