#1 | ||||
![]() Join Date: Jun 2012
Hi
I'm new to this forum and hope to get some help. 94 sl-1 4 door with manual windows. driver's window won't roll up all the way last 1/2". I guess the regulator needs work or replacement. I have removed all torq screws for the door skin to access the regualtor but the outside door handle must come off ;how ? I figure maybe some interior door panel fasteners must be removed and therefore removed 2 in the indented plastic cup shaped handle area and the one near the inner door latch ; door panel wants to come off but window crank handle must come off ,how is this done ? everything easy so far but don't know about the door handle and the window crank handle removal. Any info appreciated. Thanks in advance
#2 | ||||
From Lowsaturn's website....
http://www.differentracing.com/tech_...uterpanel.html As for the crank handle there is a clip that goes into a slot in the handle. You can use a curved pick tool or slip a thin shirt/rag against the open side and pop it off. If you push in on the door panel some and move the crank you will see the clip and it will start making sense.
| Thread Tools | |
| Display Modes | |
| Manual window problem | gearhead | S-Series Tech | 18 | 07-13-2012 10:10 AM |
| 94 sl-1 ,manual window problem | 1tealsaturn | Support Forum for Canadian Saturn Owners | 0 | 06-02-2012 01:00 PM |
| Manual Window on 98 SL | stormnorm | S-Series General | 3 | 01-17-2012 03:32 PM |
| manual window | angeltrash | Vue Mods | 2 | 04-03-2007 10:34 PM |
| 96 SL1 Manual Window Problem | wlipford | S-Series General | 6 | 01-10-2005 03:52 PM |
