Old 04-14-2012, 09:52 PM   #1
Sabi's-Saturn
Sabi's-Saturn is on a distinguished road
2005 RELAY-2
Default Peanutbutter in the Coolant overflow - DOHC '94 SL2
OK I know what ever is probably not good, but I am hoping (praying really), that there might be some other explanation for this, that isn't so expensive. I *love* my car. I do not want to give up on it.
Anyway, the car has about 203k miles on it. Had a re-manufactured engine put in 3 years ago (warranty expired last week of course). I have been pretty good about oil changes and all that. Hubby not as good but still within reason. I *just* put $800 into having the entire exhaust done after years of nearly going deaf. They also replaced a transmission gasket. I have noticed that the coolant light was flickering on now and then, figured it was a little low, and checked it this morning. The whole coolant over flow tank is filled with this tan peanut butter looking paste. I could not find coolant in it. Stinkit!
Here is a picture - (sorry had to cut the http off or it would not let me post links since I have not had 15 posts. Bah)
i1234.photobucket.com/albums/ff401/Somebirdy/coolant.jpg
And I checked the oil, the level is a little low and it is a bit overdue for a change but not to the 'add oil' area.
Here is a picture in there - (not that you can see much)
i1234.photobucket.com/albums/ff401/Somebirdy/oil.jpg
i1234.photobucket.com/albums/ff401/Somebirdy/underhood.jpg
Any other possibilities? Or are we for sure looking at head gasket?
Add to Sabi's-Saturn's Reputation
Rate the quality of this post and help Sabi's-Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sabi's-Saturn is offline   Reply With Quote
Old 04-14-2012, 10:11 PM   #2
off-track
off-track's Avatar
Default Re: Peanutbutter in the Coolant overflow - DOHC '94 SL2
Welcome! But, sorry, that really doesn't look good! Since you're just a week out of warranty it couldn't hurt to check with the shop that did the replacement. Not likely after three years but, sometimes a really good place will cut some slack.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-15-2012, 01:46 PM   #3
adventureoflink
adventureoflink's Avatar
Looks like either someone mixed coolants or it's the end result of the ginger root tablets...
Do you also get signs of blown head (gasket); overheating engine, sweet smelling white smoke cloud coming off the exhaust or underhood, coolant dripping out the exhaust with the engine off, etc?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-15-2012, 08:56 PM   #4
Sabi's-Saturn
2005 RELAY-2
I have not noticed any performance issues or overheating with it at all. It is still the zippiest car I have ever owned. (Even my old Fiero couldn't keep up with it).
I have never added ginger root tablets, but perhaps someone at the shop did? I have actually never heard of them until this forum.
Do you think if I take it up for a coolant flush/cleaning, it might be ok? I was thinking of doing this since I would at least have a better idea of what was going on (Ie I could see oil in the coolant reservoir possibly).
My dad never let me rebuild a car like he did with my brothers, and it's always been a dream of mine, so this car is sort of my 'almost' project. I really don't want to throw in the towel, but I don't have any money left, so if it's a big $$ fix, it's gonna sit for a while again.
Old 04-15-2012, 09:45 PM   #5
Sienile
Sienile is on a distinguished road
1999 SC2
Idea Re: Peanutbutter in the Coolant overflow - DOHC '94 SL2
That's what my sister always says... (see signature)
NO. Flushing at this point is just wasting money.
You already showed us pics of oil in the reservoir...
No money and you want to rebuild a Saturn engine? Well, that's not going to work at all.
You're at least going to need $35 for the head gasket, $15 for enough RTV silicone to seal the valve cover and oil pan, and another $40 for oil + filter and antifreeze. That's $90 already.
Since this is a Saturn we're talking about, you likely need to replace both front and rear main oil seals (these tend to leak like crazy, also likely the cause of the excess heat that blew the head gasket in the first place) which will run you another $30 or more.
Also, since it appears you are doing like my sister and driving the car even though it has a blown head (BTW: Keep driving with a blown head gasket and you might blow a few pistons... like my sis.), you probably need to resurface the head because it's highly likely that it's warped. Most machine shops will charge $100 for that.
Total cost of repair (Assuming the resurfacing is the only thing you do not do yourself; and that you already have a torque wrench, breaker bar, and a crank pulley puller.) is about $220. I don't know about you, but I've bought running cars for about that much.
The only good Saturn is one with a non-GM engine in it.
My sister destroys -AT LEAST ONE- 1.9 DOHC Saturn engine per year. CHECK YOUR OIL!!!
Add to Sienile's Reputation
Rate the quality of this post and help Sienile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sienile is offline   Reply With Quote
Old 04-15-2012, 10:02 PM   #6
Sienile
1999 SC2
Forgot to mention that to replace the rear main seal (if needed) you would need to remove the engine and separate it from the transmission. Rear main seal is behind the flywheel/flex-plate.
Of course to do all that you would also need an engine hoist.
If you have an oil leak between the engine and transmission, you likely need to replace this seal. Also, if it's a manual transmission and it occasionally slips or it seems to smoke a little when shifting gears, that's possibly a symptom of an oil leak.
coolant overflow after turning engine off e1geo S-Series Tech 17 02-12-2013 10:45 PM
Coolant Overflow And Radiator Fan Elit3keraed S-Series Tech 5 07-19-2010 10:51 AM
coolant overflow when car is shut off earthquakes L-Series Tech 17 09-26-2008 02:53 AM
96 sl2 p0440, p0440 & Peanutbutter milkshake in the coolant reservoir Mikeyson S-Series Tech 9 08-18-2008 05:47 AM
coolant overflow tank btrautman L-Series Tech 3 04-26-2008 10:05 PM
