Old 02-03-2010, 04:34 PM   #1
scalemechanic
scalemechanic has a spectacular aura aboutscalemechanic has a spectacular aura about
2000 SL2
Default diverter valve cleaning
Quick question. I suspect my diverter valve may be a bit clogged with soot.
What is the best way to clean it?? Can you take it apart and put it together without too much trouble?? Thanks, Jim
Add to scalemechanic's Reputation
Rate the quality of this post and help scalemechanic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scalemechanic is offline   Reply With Quote
Old 02-03-2010, 05:53 PM   #2
Default Re: diverter valve cleaning
Yes, You can remove it and apply a vacuum to it and then blow it out. Blow out the exhaust manifold also. Do not forget the connector pipe.
The diverter valve is supposed to have a check valve function so only blow air into the blower port to start with.
Old 02-04-2010, 11:53 AM   #3
scalemechanic
2000 SL2
OldNuc, when i asked if you can take the diverter apart i meant, can you
take the diverter valve itself apart by removing the two screws on the underside of it? I was thinking of taking it apart in two pieces to clean it and was wondering if it was worth the effort or, if by taking it apart it might be difficult putting it back together properly?
In the meantime i'll blow some air through the blower port as you suggested.
I've already cleaned out the exhaust manifold and connector pipe. Thanks, jim
Old 02-04-2010, 12:03 PM   #4
Never tried to take one apart. Simply an oversight though. Just open it up with a vacuum and blow it out. Usually the problem is further along in the system. The channel in the exhaust manifold fills up and stops the air flow into the exhaust stream.
P0410 Diverter valve sferguson S-Series Tech 26 05-10-2015 09:25 PM
Diverter Valve scalemechanic S-Series General 13 12-17-2009 09:44 PM
Diverter Valve scalemechanic S-Series Mods 0 12-02-2009 12:03 PM
Diverter valve sferguson S-Series Tech 0 05-09-2009 11:20 AM
Cleaning EGR valve wolfehunter S-Series General 9 07-18-2006 11:03 PM
