Old 07-12-2010, 12:17 PM   #1
Taxbert
Taxbert is on a distinguished road
Default Air Vent Control Not Working
I have a 2008 Saturn Vue. The air flow vent control is not working. The A/C works and the blower motor is working. The air is coming out by the feet, the side vents and a little out the front vents. But when I turn the dial (i.e. defroster, front vent, etc.) nothing happens. How does the vent control knob control the vents? Is it vacuum or electrical? Any thoughts on what could be wrong?
Add to Taxbert's Reputation
Rate the quality of this post and help Taxbert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Taxbert is offline   Reply With Quote
Old 07-12-2010, 03:30 PM   #2
leogag1
leogag1 is on a distinguished road
leogag1's Avatar
2009 VUE 3.6L
Default Re: Air Vent Control Not Working
It is electrical. If I were you, I'd check the cables and plugs. Maybe it's simply unplugged.
____________________________
Léo Gagné
Professional Engineer
Software Designer and Architect
Add to leogag1's Reputation
Rate the quality of this post and help leogag1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
leogag1 is offline   Reply With Quote
Old 07-12-2010, 03:56 PM   #3
smailmanstn
smailmanstn is on a distinguished road
I had a similar (if not the same) problem with my "08 XE, a little over a year ago. Under warranty, my local Saturn dealer replaced some switch or relay in the control panel.
As I recall, the A/C would only go through the floor vents, and the defrost position pushed through the front dash panel vents, as if the control switch were miswired. But i knew that wasn't the case, because the problem DEVELOPED: the controls worked correctly up to that point.
I had the impression that this was not an unknown problem. The dealership fixed it in a couple of hours (I belive a computer reset was involved). Mine has been working perfectly since. Hope this helps.
Add to smailmanstn's Reputation
Rate the quality of this post and help smailmanstn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smailmanstn is offline   Reply With Quote
Old 08-18-2014, 01:11 AM   #4
Raptorstwo
Raptorstwo is on a distinguished road
Progress report.
Finally found time to work of the switch. It was much simple that I expected.
1. Remove BEZEL. Place fingers in the 2 air vents above the radio. Give it a good sharp SHORT pull.
Short because bezel is held in place by spirng clips:
2 on top, 3 on each side, 2 at bottom. Work your way down both sides releasing clips on each side.
Note Of Caution: I don't know what kind of plastic the bezel is made of but I suspect it may be brittle when cold. You may need to warm it up if the car is very cold.
This exposes the Radio and the Heater Controls. Each are held in place by one screw of each side.
Use nut driver or socket to remove radio. (Disconnect the wiring harness at the blue connector plug, not the wide narrow grey one.)
This exposed the heater/ac controls.
I did not have to remove the heater control unit. My problem was the plastic gears at the Flow Control Switch. I was able to just turn the horizontal gear by hand which got it back into its proper position.
Swith turns like new.
Hope this works for you. Please let me know if you got this message. Good luck.
Richard.
This works. I did what Richard posted. I want to tell everyone. I've been years without after spending $600 to mechanics who couldn't fix it. Thank you Richard.
Add to Raptorstwo's Reputation
Rate the quality of this post and help Raptorstwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Raptorstwo is offline   Reply With Quote
Old 08-21-2014, 10:23 PM   #5
brwct08
brwct08 is on a distinguished road
Well I just started having the same problem. AC is blowing at feet very strong and lightly up top. I can't change it. 2008 VUE XR. I tried removing the battery for rest and it did nothing. I read online that it could be the actuator under steering column. Any help?
Add to brwct08's Reputation
Rate the quality of this post and help brwct08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brwct08 is offline   Reply With Quote
Old 09-06-2014, 09:00 AM   #6
russellgs1
russellgs1 is on a distinguished road
I just started having the similar problem as described above. AC is blowing onto the floor strong and lightly through the dash vents. I can't adjust it to any one location. 2008 VUE XE 4 Cyl. Does anyone think this tread and suggestions are relevant to this problem? Any help? Thanks in advance.
Add to russellgs1's Reputation
Rate the quality of this post and help russellgs1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
russellgs1 is offline   Reply With Quote
Old 10-06-2014, 09:48 PM   #7
tjhess74
tjhess74 is on a distinguished road
1996 SL1
this topic is my BIGGEST pet peeve with our vue. every single year about this time, our air system does this, or some strange variant thereof. in fact, we just got it back from the shop for this very thing.
four years straight now, the dealer does a reprogram and replaces the control head (the hvac dial knobs). it works great...until the following fall,.
ill take my bezel and radio out and take a gander at what you are talking about. id love for it to be so simple to shove in the dealers face. each year, i rub in the fact that they keep saying 'we finally got it this year'.
on a side note, our symptoms range from no mode control (defrost, vent, floor, etc), no temp control (ALL burning hot or all freezing cold), or both at the same time. the issues can cycle with the on/off cycle of the ignition.
the last time ours was stuck on full heat, we closed the vents, rolled down the windows on a 75 degree day while on the highway, and measured the surface temp of my dash in multiple spots with an ir temp gauge at 117 degrees!
Add to tjhess74's Reputation
Rate the quality of this post and help tjhess74 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tjhess74 is offline   Reply With Quote
Old 10-29-2015, 12:04 PM   #8
mbh47720
mbh47720 is on a distinguished road
try this from someone else on this board
and Save the trip to the dealer
Follow this procedure exactly:
Turn key on - eng not running
Calibrate the mode actuators by simultaneously pushing the A/C and RECIRC buttons on the HVAC control module 3 times each, within 2 seconds of initial push.
1. The A/C and RECIRC button LED's will flash while this calibration is taking place.
2. The calibration will take anywhere between 10 to 30 seconds depending on battery voltage.
3. The LEDs will quit flashing when the calibration is complete.
Cycle the ignition off then back on and verify proper operation
Add to mbh47720's Reputation
Rate the quality of this post and help mbh47720 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mbh47720 is offline   Reply With Quote
Old 11-07-2015, 05:06 PM   #9
mbh47720
this DID NOT work for me sorry
Old 11-30-2015, 10:34 AM   #10
carochio
carochio has a spectacular aura aboutcarochio has a spectacular aura about
Needs to be reprogrammed...
search for post# 2155261
It wont let me post the link at the moment.
Add to carochio's Reputation
Rate the quality of this post and help carochio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carochio is offline   Reply With Quote
Old 11-02-2018, 10:03 AM   #11
Kartboarder22G
Kartboarder22G is on a distinguished road
I had no heat and no vent position control. Took it to a non dealer and he changed the motor acutator for the heat control and reset the limits on it. Now when everything is set to auto I get heat just out of the floor vents mainly. Also when St to manual max heat max blower I only got the car to about 80 degrees in the cabin and that was after a 22 Mile drive and 33 degrees out. What is going on I'm bringing the car back to him soon but he is recommending a heater core flush. That still doesn't fix the vent out the bottom when in automatic mode. Help? Probably should have went to a dealer.
Add to Kartboarder22G's Reputation
Rate the quality of this post and help Kartboarder22G reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kartboarder22G is offline   Reply With Quote
cruise control not working xraytec1 Ion General 17 01-27-2019 11:48 PM
Vent Control Knob Saturn#5 Astra General 14 04-30-2009 10:07 AM
Cruise Control not working gfreek1 S-Series Tech 7 06-29-2007 12:07 PM
vent control issues racegirlfor1 Ion General 1 04-10-2007 11:49 PM
Vent control cable problems cozwurth S-Series Tech 2 08-30-2006 12:45 PM
