Old 08-24-2014, 09:23 PM   #3821
dummo
dummo will become famous soon enough
dummo's Avatar
Default Re: What did you do to your S-Series today...
After a year or so without the RKE system working and checking and re-checking fuses, I tried the checkout counter Fob tester at Advanced Auto Parts a few weeks ago and noticed the Fob not activating the unit. Thinking either I need a new battery or The Fob Checker does, I got around to installing a fresh battery I had purchased long before Obama was a US Citizen - Didn't Work. Today, I figured I'd buy a package of Two fresh 2032 batteries at The Home Depot and try again with certainty that I was being way too optimistic. I was pleasantly surprised when that did the trick!
So Dummo went a year with a dead battery in his Fob, proving that he chose a good screen name.
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 08-25-2014, 07:24 AM   #3822
BV22
BV22 will become famous soon enoughBV22 will become famous soon enough
2002 SC1
Saturday, changed the oil, filter, serpentine belt and rotated the tires. As a reward for my work, the P0420 cleared itself and the SES light went off during the post-oil change drive.
BV22
2002 SC1 5M
238k 07/14
Add to BV22's Reputation
Old 08-26-2014, 05:12 PM   #3823
Steve44
Steve44 is on a distinguished road
Steve44's Avatar
1999 SL1
Although it was yesterday, Changed the Radiator, changed the Oil and finally used a longer Filter (PH3600), changed the transmission fluid and filter, and could not believe what I saw, yup the OE filter, complete with magnet at 184,000 KM. Changed the PCV valve to the fixed orifice valve, and relubed the caliper pins.
Even though I gave the trans lines a good coating of PB Blaster 5 times during the past week, the lower line still broke . I have all of my tools, compressors, the Jack and stands at a friends place 90 minutes away since I lost the house in a breakup, and it's pretty much in the middle of nowhere. I thought I had fittings and tubing that I could make a patch line out of the way, but I guess my friends kids needed my stuff more than me. I had to use vice grips to get this fitting off of the rad, and it showed. There was no way this fitting could ever be used again. Now I was screwed. I managed to find an air fitting (for an air tool) and some neoprene line that they hadn't taken, and fortunately a couple of those "fuel injection hose" clamps. So far it's holding, and I've driven about 200kms since the repairs yesterday.
I looked at a local online auto supplier and they have the hose (apparently) and it's pretty cheap (About $25.) Only problem now, is that to replace it, I have to make the 90 minute drive, not to mention the mess, Oh man did I make a mess. Thanks goodness for Zorball.
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve44 is offline   Reply With Quote
Old 08-28-2014, 02:06 PM   #3824
NWSaturn247
NWSaturn247 is on a distinguished road
NWSaturn247's Avatar
1993 SL2
Took out the NGK G-Power spark plugs and cleaned out the wells with a paper towel wrapped around a screwdriver (affixed with tape)
The plugs are shown in order from timing chain to the right. They were installed over 4000 miles ago. The gap has not changed. These are not fine wire like the Bosch brand, but are finer than standard NGK plugs.
1993 SL2 AT - 112k
running PP 5w-20/5w-30 + Purolator PL 20195
:-) Adding TC-W3/MMO to the gas with positive results (-:
Choose the red pill
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 08-28-2014, 02:27 PM   #3825
Chazberry
Chazberry is a name known to allChazberry is a name known to allChazberry is a name known to allChazberry is a name known to allChazberry is a name known to allChazberry is a name known to all
Chazberry's Avatar
Wife drove the '95 SW2 over a curb - busted Rear Trailing Arm.
Dorman 905-811 $54.79 from Rock - easy job.
Add to Chazberry's Reputation
Old 08-28-2014, 06:05 PM   #3826
700+SL2
700+SL2 is on a distinguished road
700+SL2's Avatar
Today I saved a 99 SW2 from being scrapped. Initially to be the substitute while I tear into my SL2s engine but my wife already fell in love with it. So it looks like I'll be fighting her over it and then she'll keep it when I'm done.
So on top of what my SL needs, I'll be tending to the SW's needs as well.
Ressurecting a 1995 SL2 mileage unknown.
...and a 99 SW2 172K
Add to 700+SL2's Reputation
Rate the quality of this post and help 700+SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
700+SL2 is offline   Reply With Quote
Old 08-29-2014, 10:15 PM   #3827
catric69
catric69 is on a distinguished road
catric69's Avatar
Purchased a pair of Pioneer 6.5" two-way speakers for my front doors. I managed to install one tonight. I'll finish the second speaker install tomorrow. Hopefully!
'13 Camry SE
'13 Outback Limited 3.6R
Add to catric69's Reputation
Rate the quality of this post and help catric69 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
catric69 is offline   Reply With Quote
Old 08-30-2014, 03:43 AM   #3828
DG3
DG3 is on a distinguished road
DG3's Avatar
What did I do today? I finally got rid of my Saturn. Yay!
This was an awesome forum with a really great group of people. While I won't miss the car or the brand, if I can find a Honda forum that is half as helpful as you folks have been, I will do just fine with my new car.
Add to DG3's Reputation
Rate the quality of this post and help DG3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DG3 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 03:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 07:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 01:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 07:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 08:03 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
