Old 05-07-2012, 10:15 AM   #1
TvSteve
TvSteve is on a distinguished road
TvSteve's Avatar
1999 SW2
Default PCM generated radio noise on 146.520
I know this is a known problem but someone told me he saw a fix, filter, posted on the net. I searched high and low and had no hits. I'm taking the 99 SW2 on a road trip, NY to Colorado next month and having it would be useful. Any known workaround?
Add to TvSteve's Reputation
Rate the quality of this post and help TvSteve reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TvSteve is offline   Reply With Quote
Old 05-07-2012, 12:48 PM   #2
holydiver
holydiver is on a distinguished road
holydiver's Avatar
1996 SL2
Default Re: PCM generated radio noise on 146.520
I wish I knew...I have the same problem.
'96 Saturn SL2 5-Speed, 141k, Rebuilt Engine (My Toy)
'96 Saturn SL2 Automatic, 187k (The Project)
'02 Saturn L200 2.2L Auto, 119k (Dad's Car)
Add to holydiver's Reputation
Rate the quality of this post and help holydiver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
holydiver is offline   Reply With Quote
Old 05-07-2012, 07:41 PM   #3
adventureoflink
adventureoflink's Avatar
what exactly is this problem? is it bad? first I've heard of it to be honest...
and if this is a radio frequency I'm guessing I need an advanced radio or a police scanner to pick it up eh?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-07-2012, 09:57 PM   #4
TvSteve
TvSteve's Avatar
1999 SW2
You would need a 2 meter ham radio for this to be meaningful. The PCM is generating a rf signal that is picked up at 146.52 which just happens to be the ham 2 meter national call frequency. This has been a problem from day-1 of Saturn. I just brought it up after I was told of a possible cure.
Old 05-07-2012, 09:58 PM   #5
adventureoflink
Interesting... does anyone know what exactly is broadcasted?
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 05-07-2012, 10:07 PM   #6
Probably the processor clock frequency. High Q series resonant circuit tuned to 146.52 across the battery positive - negative for starters.
Old 05-07-2012, 10:12 PM   #7
adventureoflink
Gotcha. was gonna say it'd be interesting if it were like a subliminal message for those who have advanced radios (the HAM TvSteve speaks of, or a police scanner, etc) and somehow tuned into that frequency, it would loop "buy a saturn... buy a saturn.. a different kind of car from a different kind of company..." over and over and make you buy a Saturn.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 05-07-2012, 10:19 PM   #8
Seems to be much comment on the intertubes but a complete lack of coherent solutions. Not even any viable suggestions. Seems to be a problem on 146.79 as well which s also most likely the PCM clock in the vehicle involved.
Old 05-08-2012, 10:01 PM   #9
TvSteve
TvSteve's Avatar
1999 SW2
Your right on both points. Signal is radiated off the pcm data lines, clearly created by a cpu clock.
Old 05-08-2012, 10:25 PM   #10
Hi Q series resonant filter across battery to kill it. Batteries make real good filters but they are no good at the higher RF frequencies. The PCM cable in the car may be carefully wrapped with aluminum foil which should be grounded with a good ground strap, not wire.
Old 05-09-2012, 10:25 AM   #11
kg6mvb
kg6mvb has a spectacular aura aboutkg6mvb has a spectacular aura about
kg6mvb's Avatar
2003 ION-1 Sedan
Ouch...bad clock choice.
Along with the other suggestions, here are a few more.
An HT with the antenna removed makes a good signal sniffer. If you have too much signal, try the third harmonic (439.56).
If you can pinpoint a source, try putting a snap on ferrite core(s) over the lines as close to the source as possible. Shielding the lines can't hurt either. Finally experiment with antenna locations. You may not be able to get rid of it, but maybe you can lower the level a bit.
Good luck and 73
Proud to be a member of both the Ham Radio and Saturn Cults.
Avitar is a Saturn V rocket engine.
Add to kg6mvb's Reputation
Rate the quality of this post and help kg6mvb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kg6mvb is offline   Reply With Quote
Old 05-09-2012, 11:46 AM   #12
The Gen-2 PCM is inside the car and the entire wire bundle runs through the firewall close to the interior wire harness.
Old 05-09-2012, 12:53 PM   #13
TvSteve
TvSteve's Avatar
1999 SW2
Good luck and 73
Here's what I found. Holding an HT, no antenna, up to the OBD port S9+60, next to the battery leads 0. Have 2 snapon ferrites on all 4 of the pcm harnesses and reduced signal 2 s-units, still not usable. Signal is radiated from the data/clock lines and what makes it worse is I'm using a scanguage and a ultraguage, all plastic and excellent antennas. This is on a SW2 and antenna is on rear of roof fed with double shielded coax. Just a note, there was a posting on one of the ham boards how a fellows wife's S car would stop his scanner turning into the driveway.
Old 05-09-2012, 06:10 PM   #14
The digital data is at the data port and your scangauge and ultragauge are not helping at all. I would disconnect them and see if there is any change at all. There is only a single data line in the ALDL port unless the SDM has the same clock.
Old 05-09-2012, 07:59 PM   #15
TvSteve
TvSteve's Avatar
1999 SW2
Disconnecting makes a slight change but not worth the loss of information. If I didn't have the gauges I would just cut the data lines at the PCM and replace with shielded cable.
Old 05-09-2012, 09:56 PM   #16
That may or may not fix it.
Radio Noise holydiver S-Series General 4 03-14-2012 01:01 AM
98 SL2 radio noise rowdydog S-Series Tech 7 11-13-2011 10:10 PM
Radio Noise Cheyne S-Series Tech 17 12-01-2008 08:59 PM
Ticking noise in radio Coolspoof Miscellaneous Tech 10 07-08-2004 12:48 AM
Ticking noise in radio - possible fix on the way cgrjnky L-Series General 3 08-30-2003 06:32 AM
