#1 | ||||
![]() I know this is a known problem but someone told me he saw a fix, filter, posted on the net. I searched high and low and had no hits. I'm taking the 99 SW2 on a road trip, NY to Colorado next month and having it would be useful. Any known workaround?
#2 | ||||
![]() Join Date: Mar 2009
1996 SL2
![]() I wish I knew...I have the same problem.
... '96 Saturn SL2 5-Speed, 141k, Rebuilt Engine (My Toy) '96 Saturn SL2 Automatic, 187k (The Project) '02 Saturn L200 2.2L Auto, 119k (Dad's Car)
#3 | ||||
![]() ![]() ![]() Join Date: Apr 2009
![]() what exactly is this problem? is it bad? first I've heard of it to be honest...
and if this is a radio frequency I'm guessing I need an advanced radio or a police scanner to pick it up eh? ... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat
#4 | ||||
![]() You would need a 2 meter ham radio for this to be meaningful. The PCM is generating a rf signal that is picked up at 146.52 which just happens to be the ham 2 meter national call frequency. This has been a problem from day-1 of Saturn. I just brought it up after I was told of a possible cure.
#5 | |||||
#6 | ||||
![]() Probably the processor clock frequency. High Q series resonant circuit tuned to 146.52 across the battery positive - negative for starters.
#7 | |||||
![]() ... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat
#8 | ||||
![]() Seems to be much comment on the intertubes but a complete lack of coherent solutions. Not even any viable suggestions. Seems to be a problem on 146.79 as well which s also most likely the PCM clock in the vehicle involved.
#9 | ||||
![]() Your right on both points. Signal is radiated off the pcm data lines, clearly created by a cpu clock.
#10 | ||||
![]() Hi Q series resonant filter across battery to kill it. Batteries make real good filters but they are no good at the higher RF frequencies. The PCM cable in the car may be carefully wrapped with aluminum foil which should be grounded with a good ground strap, not wire.
#11 | ||||
![]() Ouch...bad clock choice.
Along with the other suggestions, here are a few more. An HT with the antenna removed makes a good signal sniffer. If you have too much signal, try the third harmonic (439.56). If you can pinpoint a source, try putting a snap on ferrite core(s) over the lines as close to the source as possible. Shielding the lines can't hurt either. Finally experiment with antenna locations. You may not be able to get rid of it, but maybe you can lower the level a bit. Good luck and 73 ... Proud to be a member of both the Ham Radio and Saturn Cults. Avitar is a Saturn V rocket engine.
#12 | ||||
![]() The Gen-2 PCM is inside the car and the entire wire bundle runs through the firewall close to the interior wire harness.
#13 | |||||
#14 | ||||
![]() The digital data is at the data port and your scangauge and ultragauge are not helping at all. I would disconnect them and see if there is any change at all. There is only a single data line in the ALDL port unless the SDM has the same clock.
#15 | ||||
![]() Disconnecting makes a slight change but not worth the loss of information. If I didn't have the gauges I would just cut the data lines at the PCM and replace with shielded cable.
#16 | ||||
![]() That may or may not fix it.
Radio Noise | holydiver | S-Series General | 4 | 03-14-2012 02:01 AM |
98 SL2 radio noise | rowdydog | S-Series Tech | 7 | 11-13-2011 11:10 PM |
Radio Noise | Cheyne | S-Series Tech | 17 | 12-01-2008 09:59 PM |
Ticking noise in radio | Coolspoof | Miscellaneous Tech | 10 | 07-08-2004 01:48 AM |
Ticking noise in radio - possible fix on the way | cgrjnky | L-Series General | 3 | 08-30-2003 07:32 AM |
