Old 03-16-2007, 06:44 PM   #1
Matt_Fontenot
Matt_Fontenot is on a distinguished road
Question 96 SC2 Need Help Diagnosing Problem
Yesterday while driving thick plumes of exhaust started coming out the tailpipe, and the car started running rough both at idle and while driving, but the temperature gauge was no where near the red. I do not see any oil in the coolant or vice versa. The coolant level is not low, and there is no water in the oil. Almost everyone I have talked to say that it's the head gasket or the head, but I have read that the head gasket and head on the DOHC are very reliable. I guess I'm just hoping that it's not the head gasket I was quoted around $1000+. Could it possibly be anything else or should I just face facts?
Add to Matt_Fontenot's Reputation
Rate the quality of this post and help Matt_Fontenot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Matt_Fontenot is offline   Reply With Quote
Old 03-16-2007, 06:55 PM   #2
harsha
harsha is on a distinguished road
harsha's Avatar
2006
Default Re: 96 SC2 Need Help Diagnosing Problem
Is the ECTS (engine coolant temp sensor) changed? If not, even it's not related to your problem it's good to replace it with the new style. Search for "ECTS" in how-to section of the forum.
Add to harsha's Reputation
Rate the quality of this post and help harsha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harsha is offline   Reply With Quote
Old 03-16-2007, 07:13 PM   #3
What color was the smoke? Could you tell what it smelled like?
Add to madpogue's Reputation
Old 03-16-2007, 07:26 PM   #4
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Post Re: 96 SC2 Need Help Diagnosing Problem
A fuel injector stuck open might be a possibility. Do a compression test or better yet a leak down test. Look at the condition of the plugs. Are they oil soaked, fuel soaked, etc?
Add to peppermrj's Reputation
Rate the quality of this post and help peppermrj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peppermrj is offline   Reply With Quote
Old 03-16-2007, 09:53 PM   #5
Matt_Fontenot
The exhaust was gray/white, and it smelled slightly like something was burning. Not a sweet burning smell just a slight burning smell.
Help diagnosing suspension/steering problem. cris_thomas S-Series Tech 6 07-21-2011 10:42 PM
Diagnosing no start 99 sc2 zenmodo S-Series Tech 4 12-06-2008 06:41 AM
Need Help on diagnosing problem caterpillar S-Series Tech 9 12-24-2007 11:54 AM
Need Help Diagnosing a '95 SL2 Clutch Problem Bob K S-Series General 19 11-24-2007 11:54 AM
'98 SC2 with coolant problem +unrelated clutch problem Kpendrgn S-Series Tech 11 07-12-2003 10:02 PM
