Old 03-05-2006, 12:48 AM   #1
kickflipjr
kickflipjr is on a distinguished road
Thumbs Down Torque Axis Mount (Upper Engine Mount) Problem
Well I have a problem right now. I own a 92 SL2 and all 3 of the studs of the Torque Axis Mount broke in the timing chain cover. I don't kny why it happened maybee i didn't tighten the bolts enough when i replaced it last year. Anyone have any ideas on how to get them out?
My other idea is to put the 91' engine mount system on my car (since it didn't have the tourque axis mount). Would this work?
Add to kickflipjr's Reputation
Rate the quality of this post and help kickflipjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kickflipjr is offline   Reply With Quote
Old 03-05-2006, 01:07 AM   #2
Protour
Protour is on a distinguished road
Default Re: Torque Axis Mount (Upper Engine Mount) Problem
Did they shear off flush with the block?
Add to Protour's Reputation
Rate the quality of this post and help Protour reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Protour is offline   Reply With Quote
Old 03-05-2006, 01:23 AM   #3
kickflipjr
Yes, nothing sticks out.
Old 03-05-2006, 02:26 AM   #4
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
You'll have to carefully drill into the center of each bolt and use an extractor to remove them.
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 03-05-2006, 01:23 PM   #5
Luke
Luke's Avatar
Default Was it an after-market unit ??
> Fm Kick Flip Jr <
> all 3 of the studs of the Torque Axis Mount broke in the timing chain cover. I don't kny why it happened maybe I didn't tighten the bolts enough
when i replaced it last year. <
>Did they shear off flush with the block ?? <
> Yes, nothing sticks out. <
Was it an after-market unit It was my considerable concern when I put on such a unit, and the way it fit, resulted in that very issue. The harmonics of the engine could well result in the three studs being cut into, over time, due to the after-market unit not slipping on without any rubbing on the posts.
As I've mentioned before, I took the after-market off, and replaced it with a dealer unit. The OEM unit slipped on perfectly.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 03-05-2006, 01:31 PM   #6
eljefino
eljefino's Avatar
1995 SW1
Default Re: Was it an after-market unit ??
you are lucky, in that your transmission bellhousing has vestigial mounting holes for the lower "shock absorber" 91 style mount. You would have to study a 91 subframe particularly the sub-radiator crossmember to see if this is feasible. And something's gonna need welding.
And don't forget the other mounts are different on 91 as well, like the lower mounts.
Add to eljefino's Reputation
Old 03-05-2006, 01:36 PM   #7
amazinghl
Drill and heil-coil them.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 03-10-2006, 03:28 PM   #8
kickflipjr
OK, I got everything fixed now. I used the extractor. I got one stud out with a cold engine and the other two out with a warm engine (it seemed alot easier with a warm engine).
Now here is how they broke...
I got the part from auto-zone I stopped tightening
down the nuts when i felt decent resistence. I didn't realize i hat to tighten them down quite a bit more still. I few monthes later all the studs broke. I guess the one from the saturn dealer would of had a better fit.
I made shure everything was nice and tight this time.
thanks for the help!
Upper engine mount(torque access mount) slv01sc2 S-Series General 21 08-26-2007 02:19 PM
Torque Axis Mount (Upper Engine Mount) Replacement wolfman How-To Library 29 10-30-2005 04:00 PM
Torque axis mount tore off engine!As seen on>> auxmike Miscellaneous Tech 5 09-27-2003 10:27 PM
Upper Torque Axis Mount Modification Heartbeat - '95 SL2 Mods and Performance 7 12-01-2001 12:46 AM
Torque Axis Engine Mount Nuke-Em Miscellaneous Tech 3 08-31-2001 07:41 PM
