Old 09-23-2005, 10:20 PM   #1
enviroko
enviroko is on a distinguished road
Default Need "how to" on changing an SL2 rear door skin.
or whatever you call it. The plastic only. Is this an easy thing to do? I have a 95 SL2 with a huge hole in the rear door thanks to an oops and run incident in a parking lot.
I see it uses hex screws but is there more to it than that?
Thanks!
Add to enviroko's Reputation
Rate the quality of this post and help enviroko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
enviroko is offline   Reply With Quote
Old 09-23-2005, 10:26 PM   #2
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
Default Re: Need "how to" on changing an SL2 rear door skin.
Those are Torx bolts. If you haven't already, you should pick up a set. They are used all over the car. As far as skin removal, what you see is what there is. You may have to lift or slide on some panels, but thats basically it.
Experience is something you don't get until just after you need it.
Add to dansl2's Reputation
Rate the quality of this post and help dansl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dansl2 is offline   Reply With Quote
Old 09-23-2005, 10:38 PM   #3
schultp
schultp is on a distinguished road
I've recently removed the front door outside panel. I'm sure it is similar. Here is a description. If there are subtle differences I'm sure others will help out....
You have to pull off the black plastic strip from along the top edge of the panel. This is the plastic at the outside lower base of the window.
You have to lift the outside door handle and remove the 2 plastic retaining pins that hold on the outer portion of the handle. To remove the pins, you have to push through the inner pin with a thin small screwdriver or similar tool. Then the rest of the plastic retaining pin will pull out. Find the little inner pin. You can re-use these attachments when you reassemble.
Remove all the Torx screws. Work the door skin until it comes free. There is some weather stripping that may stick to the door skin a bit.
Hope this helps. Don't force anything. Once you do all these steps the door skin should come off easily.
Paul.
Add to schultp's Reputation
Rate the quality of this post and help schultp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
schultp is offline   Reply With Quote
Old 09-24-2005, 09:57 AM   #4
enviroko
Cool, thanks. Any ideas where I might find the skin online and acutall find one of the same color?
Where do most of you look for used parts online in general?
Old 09-24-2005, 04:25 PM   #5
ScurriVision
ScurriVision is on a distinguished road
ScurriVision's Avatar
2005 VUE Red Line
Finding a match in color for a used rear door skin will take some hunting on your part. What colo are you looking for anyways??...and which rear door, driver or passenger?
Add to ScurriVision's Reputation
Rate the quality of this post and help ScurriVision reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ScurriVision is offline   Reply With Quote
Old 09-24-2005, 07:52 PM   #6
enviroko
I need the back, driver's side in teal green.
"Wrench" Light After Changing CPS, ECTS etc.. saladdin S-Series Tech 5 05-27-2010 11:02 PM
Is changing a tie rod a "do-it-yourself" job? enviroko S-Series Tech 3 09-29-2005 09:16 AM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 10:14 PM
Fuel Door - Latest "Quirk" rebelchic S-Series Tech 4 09-04-2003 09:49 PM
1st gen S-car door "skins" 1993SC2 General Saturn Discussion 4 06-12-2003 09:00 PM
