Old 09-03-2005, 10:45 PM   #1
roswell998
Guest
Posts: n/a
Question Where to purchase T115/70R14 compact spare tire?
I was checking pressure of the compact spare (I keep it at 60psi which is rated pressure) and it had split with several inches of steel belt exposed. Interestingly it did not blow out but was still holding pressure (55psi). However, obviously it's unusable.
Where can I purchase a new T11570R14 tire? The rim is like new.
Thanks
Add to roswell998's Reputation
Rate the quality of this post and help roswell998 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-03-2005, 10:55 PM   #2
acesell1
acesell1 is on a distinguished road
acesell1's Avatar
2000 L-Series 3.0L Sedan
2003 L-Series 2.2L Sedan
Default Re: Where to purchase T115/70R14 compact spare tire?
Your local junkyard is going to be the best place. It will also save you a ton of money over the dealer.
Add to acesell1's Reputation
Rate the quality of this post and help acesell1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acesell1 is offline   Reply With Quote
Old 09-03-2005, 10:59 PM   #3
roswell998
Guest
Posts: n/a
Any place other that dealer to purchase new spare tire? Also, what is cost estimate.
I was going to consider junk yard, but would prefer to just buy a new one unless the cost is outrageous.
Old 09-04-2005, 05:27 AM   #4
jeep4523
jeep4523 is on a distinguished road
You really don't wanna know how much they cost new......it's a really hard to find tire size.
You're actually better off grabbing a spare rim and having a cheap tire mounted on it and carrying around a full sized spare.
Democracy is two wolves and a sheep voting on what to have for dinner. Liberty is a well armed sheep contesting that decision.
Add to jeep4523's Reputation
Rate the quality of this post and help jeep4523 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeep4523 is offline   Reply With Quote
Old 09-04-2005, 10:08 AM   #5
patcal
patcal is on a distinguished road
patcal's Avatar
Would a full size spare fit flat in the spare tire well?
Pat Callaghan
Portland, Or.
Add to patcal's Reputation
Rate the quality of this post and help patcal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
patcal is offline   Reply With Quote
Old 09-04-2005, 10:57 AM   #6
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
No, it's just a bit too small for the tire to fit in...not deep enough either.
If you're planning on going that route, just dedicate a corner for a full-sized spare. It takes up a bit of prescious cargo room, but being able to go 80(average flow of traffic) mph on the freeway for as long as you want, as opposed to 50MPH/50 Miles that you're limited to on the spare. I think it's very well worth it.
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline   Reply With Quote
Old 09-04-2005, 11:24 AM   #7
Token
Token is on a distinguished road
Token's Avatar
1994 SW2
You should probably consider getting AAA. If you don't have it already. It's about $50 a year.
Junk yard is usually the best place for a donut.........$10
While your at the junk yard, get a full size tire with rim. ........$25
Prices will vary junk yard to junk yard.
Add to Token's Reputation
Rate the quality of this post and help Token reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Token is offline   Reply With Quote
Old 09-04-2005, 02:11 PM   #8
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Least fuss would be to get one on-line from a reputable
"parts recycler"... . Least cost would be a boneyard - but I would
want to be the one who took it out of the vehicle so I could be sure
it would fit.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 09-04-2005, 04:11 PM   #9
roswell998
Guest
Posts: n/a
Dizzy Re: Where to purchase T115/70R14 compact spare tire?
Back to the original question...........Where can I purchase a new T11570R14 tire?
Any place other than dealer?
What cost to expect from dealer?
If other sources, what cost to expect?
Old 09-04-2005, 05:15 PM   #10
Matt42
Matt42 is on a distinguished road
1993 SW2
Originally Posted by roswell998
Thanks
Same thing happened to us. We got a replacement at Discount Tire in AZ. If they are not available, try a Goodyear store. Be prepared for a special order, at what might seem like a high price. Yoiu can also try wrecking yards for a used one that might be better. Just age and ozone will do in a spare.
1993 SW2, 1996 Dodge Cummins
Add to Matt42's Reputation
Rate the quality of this post and help Matt42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Matt42 is offline   Reply With Quote
Old 09-05-2005, 09:22 PM   #11
geeminator
geeminator is on a distinguished road
Got a NEW donut off a Saturn at a Pick n Pull junkyard for 10 bucks...Car was in bad shape and the donut was never used...I believe if there are no Saturns around a Honda donut will work just as well.
Add to geeminator's Reputation
Rate the quality of this post and help geeminator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geeminator is offline   Reply With Quote
Old 09-06-2005, 09:13 AM   #12
Galileo
Galileo is on a distinguished road
Galileo's Avatar
2007 AURA XE
Good deal because a new T115/70R14 spare tire (part #09593842) has an MSRP of $91.97. I think they're so expensive because of the relatively low volume sales of donut spares.
Beautiful People First~
Add to Galileo's Reputation
Rate the quality of this post and help Galileo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Galileo is offline   Reply With Quote
Old 07-15-2008, 01:18 PM   #13
dobsonjs
dobsonjs is on a distinguished road
1998 SW2
I doubt this will be of use to the original post author, but others may benefit.
Finding a NEW compact spare was more of a challenge than I thought. The tire size is T115/70-R14. I called a Firestone dealer, a Saturn dealer, Firestone.com, TireRack.com and a few other online retailers. Nobody sold that size tire! Instead they suggested I look in a junk yard. Like I needed another OLD tire. That was my problem to begin with - the tire's tread split because of old age.
Finally, I found that my local Goodyear dealer could order a replacement, a Yokahama T115/70/D14. Different tire technology, but the same size.
After I had already ordered the Yokahama I got a response from Firestone.com. They said that the tire could be ordered through a local dealer. Why didn't the local dealer mention that???
Anyway, I hope this post helps someone avoid a similar struggle. Have you checked the condition of your S-Series compact spare lately?
Add to dobsonjs's Reputation
Rate the quality of this post and help dobsonjs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dobsonjs is offline   Reply With Quote
Old 07-15-2008, 01:32 PM   #14
Originally Posted by dobsonjs View Post
...the tire's tread split because of old age.
No, it didn't. There was a defect, or something came in contact with it and damaged it. Old tires ROT, they don't split. There would've been dry rot all over that tire long before it split. But with no sun exposure, that would take decades. Tour any salvage yard and look for donut spares damaged the way yours is. On a good day, you might find one.
A full-size spare takes up a LOT more than "a corner" of the cargo area. It's also dangerous to have it loose back there (there's a reason the spare is bolted down). AAA or BetterWorld Club is a good idea for any car our age; towing coverage for an old car is WAY cheaper than high-premium insuarance for a newer car. But it's no substitute, esp. in the eyes of the law, for a working spare.
Add to madpogue's Reputation
Old 07-15-2008, 03:49 PM   #15
OnDaGround
OnDaGround's Avatar
1993 SC2
Originally Posted by roswell998 View Post
Thanks
Get a new one... you don't want anyone else's junk. You could probably get it from tirerack.com for a decent price and if you have never used them they are cheap and reliable. They won't steal you credit card number and run away... They are a huge company and alot of dealerships use them including mine. and my previous dealerships. they cover all name brand tires... you name it they got it.
Saturnless...
Old 07-15-2008, 06:24 PM   #16
MikeNW
MikeNW's Avatar
1997 SL
You can have mine for $20. I have a full sized spare in the trunk. For all the reasons already given. Except that you are in Atlanta.
I would never go on any trip farther than 10 miles from home, without a full sized spare.
NO, a full sized spare does not fit in the trunk well. Thanks Saturn.
By about 1/2 inch diameter. I would be happy if it set in there, never mind the height problem.
I think the team who worked on the trunk design, had just finished figuring out where to put the oil filter Same lack of thought in each case....
(Jeez, even my base model 77 Rabbit had a full sized spare! )
08 Burgman 400
Add to MikeNW's Reputation
Old 04-13-2010, 12:37 PM   #17
RadioRon
RadioRon is on a distinguished road
I appreciate all of the information on the Saturn donut spare situation. My concern/question is how long I should let my original, unused, spare go before replacing it simply for safety-sake?
This infomration, obviously, would apply to any vehicle, not just Saturns.
I have an '01 SL2, so my spare is coming up on its 10th birthday. I would assume that age must be a factor by this point.... and that 9 out of 10 people with cars of this age or older never even think of this issue.
Add to RadioRon's Reputation
Rate the quality of this post and help RadioRon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RadioRon is offline   Reply With Quote
Old 04-13-2010, 01:22 PM   #18
Low Saturn
Low Saturn's Avatar
2000 SC2
If kept in the trunk, inflated to close to the proper level and not exposed to any harsh chemicals, it should outlast the rest of the car and its owner.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 04-13-2010, 01:46 PM   #19
Kaervak
Kaervak will become famous soon enoughKaervak will become famous soon enough
Kaervak's Avatar
Yep. 99 SL2 here. It's been parked outside in eleven years of northeast Ohio weather and the compact spare (never used) looks brand new. Holds pressure just fine and no damage/separation to the tire at all.
Add to Kaervak's Reputation
Rate the quality of this post and help Kaervak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaervak is offline   Reply With Quote
Old 04-13-2010, 03:34 PM   #20
Beachbaby902
Beachbaby902 is on a distinguished road
Beachbaby902's Avatar
2007 AURA XE
I have a regular full size 175-70R-14 in place of my spare.
My spare blew up and i put a very bald(pervious owner) tire in place that works fine. It sticks up a little, but i like i better that way because the board doesn't bow if you put something heavy in the middle.
I think i'd be best to have one of those instead of a regular spare tire.
Add to Beachbaby902's Reputation
Rate the quality of this post and help Beachbaby902 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Beachbaby902 is offline   Reply With Quote
Anyone know where I can purchase a spare Astra ECU from used? Suns_PSD Astra General 2 02-23-2009 08:10 PM
compact spare tire mrriden S-Series Tech 4 11-18-2008 10:33 AM
Spare Tire Spl170s Vue Red Line 0 09-26-2008 03:51 PM
No spare tire! safemom Vue Green Line 13 12-27-2006 03:06 PM
Spare Tire trans4mer S-Series Tech 8 11-09-2002 10:07 PM
