Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 06-30-2005, 01:34 AM   #1
Sony
Sony is on a distinguished road
1994 SC2
Default question on sc2 speed chips on ebay
OK, now is it worth buying those speed chips that are on ebay that promise to gain you 15-20 hp for your sc2 by just plugging them into your mass-airflow sensor. or are they just a load of bull?
Add to Sony's Reputation
Rate the quality of this post and help Sony reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sony is offline
Old 06-30-2005, 02:09 AM   #2
GmG
GmG is on a distinguished road
GmG's Avatar
1992 SC
Default Re: question on sc2 speed chips on ebay
Your skepticism is well founded, they are a load of bull. Ditto for the $30 "electric superchargers".
George
92 SCm 138k
98 SC2m 131k
"You shouldn't leave things in the fridge. That is the lesson."
Add to GmG's Reputation
Rate the quality of this post and help GmG reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GmG is offline
Old 06-30-2005, 02:11 AM   #3
SKILMATIC
SKILMATIC is on a distinguished road
Yeah I really havent seen any dyno sheets to prove that they work so I cant tell you that they do. I just dont know. But I can telll you they prolly dont. Try checking there feedback for there product.
Add to SKILMATIC's Reputation
Rate the quality of this post and help SKILMATIC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SKILMATIC is offline
Old 06-30-2005, 09:30 AM   #4
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
You know skilmatic, sometimes you can just use your brain to figure out how much of a piece a product like that is.
Don't waste your money!
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline
Old 06-30-2005, 10:30 AM   #5
Sony
1994 SC2
Default Thankyou
Well i would like to thank you guys for the help and thankyou for saving me my money.
-Rick
Sony is offline
Old 06-30-2005, 10:52 AM   #6
mars_volta
mars_volta is on a distinguished road
mars_volta's Avatar
its usually a resistor that plugs into the IAT (intake air temp) and fools the PCM into making the car run richer or leaner. dont know..since i dont know what value the resistor is.. stock IAT is about 3500 ohms IIRC.
anyway, your car will not run properly and may lose power and gas mileage.
get a SAFCII and tune out the rich spots at WOT. you can pick up 15 whp just by doing that.
Add to mars_volta's Reputation
Rate the quality of this post and help mars_volta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mars_volta is offline
Old 06-30-2005, 11:13 AM   #7
Sony
1994 SC2
Default ok im just a noobie
well hey im new to this scene, and i dont quite know alot. would you mind telling me what an safcII is?
Sony is offline
Old 06-30-2005, 12:19 PM   #8
sps SOHC
sps SOHC's Avatar
Default Re: ok im just a noobie
The Apex-i Super Air Fuel Computer II is a small computer (about the size of some radar detectors) that has an LED screen. You wire the computer into your PCM. It reads current air/fuel ratios and allows for adjustment of those ratios. Tuning your car on a Dyno w/ an SAFC can result in as much as 15 whp (w/ bolt ons, probably not stock).
It is an EXCELLENT thing to purchase for a quick increase in HP but only if you have a dyno to go tune it on. There are no dyno's in this area (except one that only does RWD) so I had to pass on it for now.
An excellent site with Installation instructions and how to set it all up: http://www.turbosaturns.net/articles/SAFC%20install.htm
can't get better than that!
sps SOHC is offline
Old 06-30-2005, 12:22 PM   #9
ud503j
ud503j is on a distinguished road
ud503j's Avatar
1997 SW2
The Super AFC II (Air Flow Converter) is the industry standard for sub computer fuel control. The S-AFC II is designed to fine tune and "squeeze" power out of existing engine setups by allowing the user to modify the fuel curve with precision accuracy. Since the act of simply bolting on performance products does not make maximum horsepower, the S-AFC II allows the user to calibrate the fuel system in accordance with performance upgrades as they are installed. The AFC modifies the air flow meter/ pressure sensor signal voltage going to the factory ECU (Engine Control Unit) to change the amount of fuel injected. The S-AFC II utilizes a VFD (Vacuum Florescent Display) to display critical data in three different modes.
You can pick them up on ebay for around 100 bux usually. If you plan on doing any kind of tuning in your car, adding a turbo or supercharger, even doing any kind of nitrous, eventually you'll want one of these.
1997 SW2 --> 'Vi'
g/f's 2002 SL2 --> 'Raven'
R4V3n SP33D's boytoy!
Add to ud503j's Reputation
Rate the quality of this post and help ud503j reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ud503j is offline
Old 06-30-2005, 01:27 PM   #10
SKILMATIC
And dont forget you have 2 different ones you have the SAFC1 and the SAFC2. If you go turbo you will prolly want something a little better than just a safc. Just my opinion.
Old 06-30-2005, 01:40 PM   #11
sps SOHC
sps SOHC's Avatar
the main difference between the SAFC I and the SAFC II is the adjustment points in your RPM range. the SAFC I allows for 8 adjusment points while the SAFC II allows for 12 adjustment points. I don't believe the SAFC I has the knock sensor like the second one.
sps SOHC is offline
'01 Speed Chip and Speed Boost? (from eBay) Disturbed_One S-Series Mods 46 02-23-2008 01:11 PM
Anyone tried those cheap chips or superchargers off ebay? ejb S-Series General 9 09-10-2005 10:09 PM
FS: 5 Speed Transmission from 98 SC1 eBay CorradoKidd Classifieds 0 09-09-2005 06:23 PM
Non-ebay performance chips adamv3 Mods and Performance 12 04-21-2005 08:08 PM
Speed Chip On Ebay So_Lo_Saturn Mods and Performance 27 02-05-2005 09:18 PM
