Old 03-01-2005, 03:51 PM   #1
W. Kindel
W. Kindel is on a distinguished road
W. Kindel's Avatar
1997 SL
2002 L-Series 2.2L Wagon
Default Location of BCM
Greetings, Saturn Wizards!
I'm having an intermittent electical disease in my 2002 LW-2 (or is it LW-200?) which I've gleaned from this forum may be something loose in or around the BCM. The symptoms: When in motion, and when the outside temperature is in the 50's, the Temp and Gas gauges intermittently drop to zero, along with the running lights shutting down. When gauges return to normal readings after a second or two, the "Security" dash light will glow for second or so - sometimes the door locks click a little, though usually not. (Yesterday the tailgate door mysteriously unlocked itself while I was on the road.)
I've read in other posts that the BCM could be nearing death, but I'd like to eyeball it myself and check for loose plug-ins, etc. before taking the rascal to my friendly Saturn dealer. Where would I look for it?
Many thanks!
Add to W. Kindel's Reputation
Rate the quality of this post and help W. Kindel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
W. Kindel is offline
Old 03-01-2005, 10:58 PM   #2
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default Re: Location of BCM
It's located on top of the glove box.
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline
Old 03-02-2005, 12:34 AM   #3
1stSaturnowner
1stSaturnowner is on a distinguished road
1stSaturnowner's Avatar
2001 L-Series 2.2L Sedan
Where would you find the BCM on a 2.2L I4 L100/L-series?
Add to 1stSaturnowner's Reputation
Rate the quality of this post and help 1stSaturnowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1stSaturnowner is offline
Old 03-02-2005, 01:48 AM   #4
All the L-series car should have the BCM located on top of the glove box.
Add to ssicarman's Reputation
ssicarman is offline
Old 03-03-2005, 11:09 AM   #5
W. Kindel
W. Kindel's Avatar
1997 SL
Thanks, all, for the info about where I might find the BCM. Since making my initial post above, however, the L-Machine decided to have a stroke, lapsing into deep brain death. Car got hauled away on flatbed yesterday.
Since a brain-dead Saturn L-Machine can't be shifted out of Park, the tow operator simply dragged the car down the driveway with wheels locked by the transmission. Is it likely anything was damaged? Is there a simple way to get a locked-up LW-200's automatic tranny out of Park when the brains are saying "No!"?
Many thanks!
Old 03-03-2005, 09:35 PM   #6
lostwages_ls2
The procedeure is in the owners manual. You pull up on the bezel around the shifter, then manually release the pin that holds the shifter in park.
BCM location? Polished 2007 Vue Mods 1 12-01-2009 11:14 PM
BCM Location Mil Astra General 15 03-12-2009 06:25 PM
Could this be another BCM Al10453 L-Series Tech 6 07-17-2008 11:24 AM
Location, Location,...CPS Location? saturn94v S-Series Tech 6 05-21-2008 10:50 PM
What does the BCM do, exactly? kpatz General Saturn Discussion 4 03-21-2006 04:26 AM
