Old 12-18-2004, 09:12 PM   #1
wojtek_f
wojtek_f is on a distinguished road
Default windscreen cracked - frame bent??
Hey
I just noticed a disturbing crack in the corner of the windscreen (top on passenger side).
- It might have been there for a while since it's entirely on the part that's 'blackened out' so I might have just not noticed...
It doesn't look like caused by an imact from some debris though... The pattern is a cross but the pieces close to the frame are a bit displaced. the lines of the cross are about 3inces long and the 'point' is about 1 inch from the corner
I've had some brake problems lately so the car was lifted and lowered a lot. Could this be caused by the frame flexing while doing that or during corenring...
(The car is quite old: 1993 SL1 with 197000km on it)
thanks for your comments
Wojtek
Add to wojtek_f's Reputation
Rate the quality of this post and help wojtek_f reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wojtek_f is offline
Old 12-18-2004, 09:57 PM   #2
wolfman
wolfman's Avatar
Default Re: windscreen cracked - frame bent??
The windshield sits on a "pad" of rubber like adheasive and as several stress mounting pads positioned around it's perimeter. Shy of twisting the car like taffy you should not be able to crack the winshield from the activities of jacking up or otherwise lifting the vehicle.
Add to wolfman's Reputation
wolfman is offline
Old 12-19-2004, 09:58 AM   #3
eljefino
eljefino's Avatar
1995 SW1
I got a crack in my old cutlass ciera windshield just like you describe after hitting a mega-frost heave one March. The windshield is a structural part of most unibody cars. I would expect the saturn to be a bit stiffer than that rattly olds though. Did you have the doors open when you were jacking the car up? They should be shut to add rigidity.
I'm not suggesting the S-cars are flimsy and the windshield will break when you change a tire... but that your hypothesis does hold water to me at least.
Add to eljefino's Reputation
eljefino is offline
Cracked windscreen Michel1961 Aura General 7 09-14-2009 06:56 PM
Bent Frame on SC2 can it be fixed? mile2885 S-Series General 5 07-28-2007 05:57 PM
driver seat metal back frame bent Blue92SL2 S-Series Tech 3 02-05-2006 05:56 PM
Bent Sub Frame Dipsetct22 S-Series General 8 07-05-2004 08:55 PM
My frame is bent is this fixable vue4u2nv Vue General 5 01-11-2004 01:37 PM
