Old 10-19-2005, 05:28 PM   #21
sierrap615
sierrap615's Avatar
Default Re: P0340/P0341 Troubleshooting S-Series
Originally Posted by ssicarman
So far as I know this is also the part number that we use on all S-series up to 2002 not that we have many problems with those years with the coils.
i checked the spec for 91-95, it is 7K-10Kohm, 96+ is 8K-15Kohms. perhaps the service part coil can replace the OBD-I coils dispite they have different specs? i assume the OBD2 coil outputs more spark energy. and i would agree the coils are very relible. one of my coils have an internal open on the secondary side and without a ohmmeter you would never know. it fires strong
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 10-29-2005, 11:28 AM   #22
metamp
metamp is on a distinguished road
good post but the anything after step 9 is rocket science to me
my 2002 SL is still dead and It looks I'm gona get ripped off at saturn dealership or the junk needs to be ditched
2002 SL = my nightmare
Add to metamp's Reputation
Rate the quality of this post and help metamp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
metamp is offline
Old 10-29-2005, 04:49 PM   #23
97sc2leather
97sc2leather is on a distinguished road
hello i bought a 97 sc2 the car started running like crap 2 days later i brought it to autozone the compter gave me the cam shaft position sensor code and a cylinder 1 misfire code and a ects code i bought the ects changed it the codes gone i bought 4 sets of plugs each one sucked i had + 4's reg bosch denso iridiums and now ac delco i bought msd wires those seem good i bought msd coils i put it all in the car all errors were gone for about 5 minutes then i got a cyl 4 misfire p0304 i changed the gas filter i tested the compression i brought it to a lot of shops i tested all the ohms on wires coils ect. they were all good the computer came up with nothing the car would miss then not miss depending on how the car felt that minute i just read this post i went outside and took the 1/4 msd coil of the car and put the stock one i replaced back on the car my cyl 4 misfire is now gone but i now have a cyl 1 misfire would i be wron to assume that the resistance difference in the msd coils were causing my cyl 4(cam shaft position sensor) error and that my stock coil is bad on the number 1 cyl? and that if i put a stock 1/4 coil back on there it will go away?
Add to 97sc2leather's Reputation
Rate the quality of this post and help 97sc2leather reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97sc2leather is offline
Old 10-29-2005, 06:01 PM   #24
97sc2leather
bought a stock coil new put it on same thing cyl 1 misfire i give up
P0301 p0340 esrussell S-Series Tech 11 10-12-2008 10:25 PM
99 Sl1..p0340,p0341,p0302 Stillwater S-Series Tech 19 09-20-2008 06:36 PM
P0340 killing me! danwhitney L-Series Tech 7 07-27-2008 12:51 AM
'99 SL2 codes...P0341, P1599, P0340, P0410 harorider S-Series Tech 3 03-23-2007 03:41 PM
Still need help with P0340 code jegster S-Series Tech 7 07-01-2003 11:39 PM
