Old 08-01-2004, 10:49 PM   #1
silverblueL200
silverblueL200 is on a distinguished road
silverblueL200's Avatar
Default Starter hanging on cold starts, I think?
At least I assume it is, if the car sits for the day while I'm at work, there will be a kinda loud grinding noise right as the car starts @ I release the key. Now this weekend, when I didn't use the car at all, I went to go out tonight and the grinding noise sent chills down my back it was so loud. Now the only thing that is wierd to me is that everytime I get this grinding noise, when I turn the A/C on I get the same noise, thats kinda makes me think its not the starter, but I'm no tech so I don't know....
Any opinions would be much apprecieted.
- 2003 Saab 9-3 Arc
Hello, mother. I come bearing a gift. I'll give you a hint. It's in my diaper and it's not a toaster. -Stewie Griffin
Add to silverblueL200's Reputation
Rate the quality of this post and help silverblueL200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverblueL200 is offline
Old 08-01-2004, 11:26 PM   #2
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
Sounds like the A/C compressor clutch.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline
Old 08-01-2004, 11:29 PM   #3
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
Default
My VUE's 1st and now 2nd starter has always grinded/rattled every so often.
The fact that your noise occurs with the engagement of the compressor means though it might be more likely to have somthing to do with the compressor or its clutch, since I the 2.2's do also have the compressor clutch engaged while cranking to help oil the A/C system.
Add to MaxSL2's Reputation
Rate the quality of this post and help MaxSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MaxSL2 is offline
Old 08-01-2004, 11:34 PM   #4
silverblueL200
Default
Okay, well on the A/C theory, I had a strange thing happen 3 weeks ago, I was sitting waiting to turn into a gas station, it took a few minutes for traffic to clear, as I'm sitting there I realize I'm feeling warm air. I look down and the A/C light is off, button is still depressed. I cuss at it, turn the fan off, turn it back on & the engine shudders and the RPM's down to ~400 then go back to normal. Hasn't done this again since.
- 2003 Saab 9-3 Arc
Old 08-02-2004, 12:07 AM   #5
lostwages_ls2
Default
1st the good news... If it is the clutch, it is a separate replaceable part.
Now the bad news. It costs about $200. And 3.5 hours labor.
Obey the Min Pin
Old 08-02-2004, 12:10 AM   #6
silverblueL200
Default
I could've done without the bad news
What happens if I just let it die, is it going to take the compressor down with it?
- 2003 Saab 9-3 Arc
Old 08-02-2004, 12:59 AM   #7
lostwages_ls2
Default
Before we blame it on the clutch, how old is the serpentine belt??? Could it be slipping when the A/C engages?
Obey the Min Pin
Old 08-02-2004, 01:37 AM   #8
wolfman
wolfman's Avatar
Default
If this noise is basically duplicatable at this point (happens nearly all the time) you can confirm if it's the A/C compressor clutch by removing the belt and starting the car. Noise gone? Diagnosis confirmed that at least it IS SOMETHING belt driven. Based on your other symptom descriptions, the A/C compressor clutch becomes prime suspect #1.
Add to wolfman's Reputation
wolfman is offline
Old 08-02-2004, 11:22 AM   #9
silverblueL200
Default
Car only has 46K miles on it. I guess I will have to start troubleshooting it, thanks for the tip Wolfman.
- 2003 Saab 9-3 Arc
97 SL1 Cold Starts vs. Hot Starts and ECT edk S-Series General 7 02-23-2005 01:33 AM
cold starts with redline amishland Ion General 21 10-21-2004 10:06 AM
hard cold starts samiam L-Series General 13 07-24-2004 11:48 PM
92 SL--starts then dies when cold firecadet613 S-Series Tech 9 01-18-2004 06:46 PM
Starts in cold then dies, then starts again ??? Scyan S-Series Tech 10 02-16-2003 10:16 PM
