Old 01-13-2020, 12:42 PM   #1
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Default New Fuel Pump for a 97
I want to finally replace the fuel pump in my 97. Are the any brands I should stay away from? Spectra Premium seems to be the most bought in RockAuto, but it has bad reviews on amazon. Is Carter still a good brand? Ive seen that mentioned here before.
Thanks for the help
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-13-2020, 10:07 PM   #2
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
Default Re: New Fuel Pump for a 97
Q: Does your 97 suffer from the bad starting up issue like mine is? after sitting a few minutes from turning off - it hesitates and takes a few tries with the turn of the key to get fuel flowing properly? (some sort of valve defect in the 97 fuel pumps ??)
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 01-13-2020, 11:54 PM   #3
Zeebins
Zeebins's Avatar
It does, and I do wait for the fuel pump to prime before starting. My remote starter doesn't wait long enough though so it will sometimes struggle to start.
I had a feeling I would have this problem after getting the remote starter. I've wanted to replace it for a while now for convenience sake anyway.
Powered by Plastic
Old 01-14-2020, 12:01 AM   #4
Zeebins
Zeebins's Avatar
I was also looking at this thread on how to replace the pump. The pics no longer work unfortunately...Is there a Richpin video on this, lol
http://www.saturnfans.com/forums/sho...d.php?t=142900
Powered by Plastic
Old 01-14-2020, 10:15 AM   #5
ShawnV took out more than I needed to on both a '93 SL2 and '96 SC2, but it reads as if he managed to get the tank out with the back end just lifted on standard height ramps (I had to jack both to the sky with the front bumper on the ground).
FSM guides attached.
This job is the only reason I can think of to run the gas tank dry. Run it as empty as you can, fill-up a 5gal can to put gas in when your done if you get worried about making the station afterward...the less gas in the tank when you start & the better off you'll be.
Old 01-14-2020, 02:22 PM   #6
alakai66
alakai66 is on a distinguished road
alakai66's Avatar
Thanks for the help
I had to replace mine recently. Brought the DELPHI FG0412 from Rockauto. Works fine for me. I had to replace mine because the hoses to the pump was leaking gas. Killed two birds with one stone. Hope you find what your looking for! Aloha!
"I find your lack of faith...disturbing!" - Darth Vader *Probably*
Add to alakai66's Reputation
Rate the quality of this post and help alakai66 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alakai66 is offline   Reply With Quote
Old 01-14-2020, 05:08 PM   #7
dummo
dummo's Avatar
1997 SW2
Too bad there wasn't a recall for this issue with our 97's
1994 SL1 new traded
Old 01-14-2020, 10:31 PM   #8
SRGW
1997 SL1
Post Re: New Fuel Pump for a 97
I took the easy way out. I wired a momentary push switch across the fuel pump relay. Get in car push switch for 7 seconds then normal turn key to start. Works every time
1995 SL1 236,300 2005>2018
1997 SL1 81,200 2014>????
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-14-2020, 10:36 PM   #9
Zeebins
Zeebins's Avatar
There was a factory service bulletin on the 97 pumps. Im pretty sure it only extended the warranty on the fuel pumps though, which are now long expired anyway.
Does anyone know if there is a sock/filter for the pump and the housing? I cant tell from the FSM if there is one for both of not.
Powered by Plastic
Old 01-15-2020, 12:58 AM   #10
There is an in-tank filter, not sure what you'd call it. It snaps onto the intake port on the fuel pump. The new pump should come with one.
Old 01-22-2020, 01:48 PM   #11
Zeebins
Zeebins's Avatar
I probably wont be doing the pump until it gets warmer out, but I did get this in the mail last night. Should hopefully make getting the old pump out easy.
File Type: jpg C7F55861-25E7-4D8B-A002-4D534B33E0BB.jpg (137.5 KB, 0 views)
Powered by Plastic
Old 01-23-2020, 10:34 PM   #12
38TransAM
38TransAM has a spectacular aura about38TransAM has a spectacular aura about38TransAM has a spectacular aura about
My 9 yr old took my ring off with a screw driver wrapped around a rag and a hammer.
Among other Saturn fun my fuel pump took a crap Christmas Day.
Saturn OEM GM reman. engine NO LONGER AVAILABLE (SOLD OUT)
96 SL2 still kicking at 186k???(for sale, needs brake line)
99 HCE 63k Now at 97k and new GM reman engine, 132k
Add to 38TransAM's Reputation
Rate the quality of this post and help 38TransAM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
38TransAM is offline   Reply With Quote
Old 01-31-2020, 03:43 PM   #13
Zeebins
Zeebins's Avatar
I think I discovered something new about my current fuel pump. Not only does it loose pressure quicker with a warmed up engine, it struggles to regain pressure when parked up hill. Even after cycling the key twice to prime the pump, it almost stalled starting. Ill have to try priming it more next time and see it that helps.
Powered by Plastic
Old 02-10-2020, 11:56 PM   #14
TomM96
Z-
Re '97 fuel system:
1.) I never had the issue ... Madpogue, a onetime Sat Tech, suggests/
just turn SW to Ig ON, then leisurely fasten seatbelt, then turn to 'Start'.
{assumes manual ops}.
2.) If you are still using the original Fuel Pressure Regulator, it might help to install a new regulator.
I measured the pressure on mine, and observed varied output press with varied vacuum, all within spec. But I renewed the part based on gut disgust ... and the engine performance improved much.
3.) OldNuc suggested to use the Carter pump (only); Delphi/Delco prolly OK.
4.) You may want to lubricate the fastenings securing the Straps which support the tank a few days before the planned Swap ops; maybe loosen the
fasteners.... check for security. Maybe procure some replacement tank straps beforehand. Hopefully the attachments are OK.
5.) Nice OTC special tool.
You may want to procure a new tank seal/attachment ring/oring.
The flattish steel ring is rotated beneath a mating/matching ring on the tank, whilst compressing slightly the elastic oring into a mating groove between the tank-ring(s). The steel may be rusted stationary, with accumulated sand and corrosion products. A dull screwdriver (or flat-tipped punch) may be more suitable to loosen/disjar the steel sealing ring from its rusted intimacy with the adjacent similar part on the tank. That is, the torque required to turn the OTC wrench when the thing is rusted in place may be excessive. Also, these rings
-- similar design on '73 & '95 Chevy pickups -- have provision for some lateral 'play', so they sometimes need 'centering' to align cutouts, etc, etc.
The wrench may be ideal After the seal ring has been tapped loose & jiggled about a bit; it will probably be nice for the installation aspect too.
Add to TomM96's Reputation
2002 SL1, no fuel pump signal, no spark, fuel on empty U2LN S-Series Tech 18 09-11-2019 06:12 PM
Saturn SC2 with P0171. Replaced Fuel Pump and Fuel Filter. Natelancer S-Series Tech 13 03-16-2017 05:13 PM
Fuel Pump Troubleshooting results. Bad pump? saladdin S-Series Tech 13 02-14-2013 10:39 AM
I don't have a fuel pressure gauge, is there a way to check problem fuel pump without dddaaa S-Series Tech 6 08-06-2011 03:09 PM
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 12:34 PM
