Old 12-29-2019, 10:35 PM   #1
trainer
trainer is on a distinguished road
Default How many qts tran fluid
Have 95 sc2 taat transmission needing to replace 2 cv Drive axles that means draining trans fluid.
How many qts does entire trans hold, about how much gts lost wen replacing 2 drive axles. need enough on hand. Thanks.
Add to trainer's Reputation
Rate the quality of this post and help trainer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trainer is offline   Reply With Quote
Old 12-29-2019, 11:05 PM   #2
Default Re: How many qts tran fluid
Around 8qt's bone dry, about half that with a drain & refill.
You can minimize the loss by only jacking up 1 corner at a time and getting that side as high as possible rather than just high enough to get the wheel off.
Unexpected tran fluid change RobertGary1 Vue Tech 1 03-06-2016 07:38 PM
L300 Tran Fluid Leak saturnsince96 L-Series General 4 09-20-2011 08:46 PM
2003 vue 3.0 awd tran fluid question medic550 Vue Tech 5 10-05-2009 08:17 PM
Confused on how to change transmission fluid for auto tran Sl2 mlambert77 S-Series Tech 16 08-13-2006 09:41 PM
03 ION-3 AF23 Tran Fluid Change Results. lgodave Ion General 18 12-17-2005 12:18 AM
