Old 12-17-2015, 04:40 AM   #1
mrhappypantz
mrhappypantz is on a distinguished road
Default 2002 saturn l300 3.0 rad drain exact location or pic of the location??
hi, i cant seem to find the rad petcok on radiator, im sure its on bottom but i cant seem to find it and if i did how do i access it to remove? also, to check the trans fluid in this car without dipstick i know theres a plug i have to remove etc and see if it drains out, but they say (make sure car level? in my mind the car as it sits really isnt level is it? seems the front would be lower anyway with motor etc? without exact science how could i check it at home and at least have a good idea if it may be low etc? thanks in advance
Add to mrhappypantz's Reputation
Rate the quality of this post and help mrhappypantz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrhappypantz is offline   Reply With Quote
Old 12-17-2015, 07:20 AM   #2
thepat
thepat has a spectacular aura aboutthepat has a spectacular aura about
Default Re: 2002 saturn l300 3.0 rad drain exact location or pic of the location??
See attached picture for your radiator questions. The part I circled in red is the the drain screw. The item in blue is the drain. Note that both are on the passenger side. The drain faces the rear of the car. There is a splash shield attached to the front subframe which you should remove if you are not going to attach a rubber line to the drain. Otherwise, the coolant will drain onto the plash shield and get everywhere.
Add to thepat's Reputation
Rate the quality of this post and help thepat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thepat is offline   Reply With Quote
Old 12-17-2015, 09:11 AM   #3
mrhappypantz
Thank u very much, does the screw just loosen up? I don't need to it out completely? Exactly how does it loosen? Looks like storage looking petcock. Does this car have a bleeder anywhere? Just curious going to drain coolant and refill and I'm sure there will be air introduced?
Old 12-17-2015, 01:35 PM   #4
pierrot
pierrot's Avatar
The drain cock is not removed. As you loosen it the antifreeze will begin to drain more and more swiftly.
You may need to use pliers to break it loose initially, but be careful as the piece is plastic. Once the drain cock is loose you should be able do it all by hand. There is a nipple (pointing down or sideways I cannot recall) through which the antifreeze will drain. I suggest that you find a piece of tubing to attach to it - at least a foot in length, more is probably better and it's not expensive - so that the cooling system will drain easily into a pan and not spread itself through the front of the sub-frame and make a larger mess. A 3/8" i.d. hose should be adequate.
None that I know of. I found that the recommendation to squeeze the upper radiator hose several times after the initial refill, but prior to running the engine, was useful.
Yes, air is always introduced into the system following a cooling system flush/drain. It takes several minutes of running the engine at operating temperature to bleed air from it. Be patient. Watch for air bubbles appearing in the antifreeze tank. When you no longer see any and the antifreeze level is correct then the bleeding is complete. As a follow-up, check the antifreeze level the next morning. If required, add whatever amount may be needed and the job is done completely.
Take a look at the link below. It should answer your questions. The hex on the inspection plug is 11 mm. Use a quarter drive ratchet, short extension, and socket for removal. The reason for making sure that the car is level is because the car must be elevated to access the inspection plug.
http://www.saturnfans.com/forums/sho...smission+drain
326,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 12-17-2015, 08:37 PM   #5
I've found that in two coolant replacement procedures, draining only allowed a little more than a gallon. My system would only take a little more than a gallon of water to top off for a second flush as the first flush still contained Dexcool (now diluted), requiring a second flush to rid the system of old coolant. Once drained of flush water, a full gallon of Dexcool filled the system with very little make up water needed. Apparently the engine and heater holds onto coolant. L300's take just under two gallons of coolant so a full gallon of 100% antifreeze of choice should fill a system to capacity. Just let the engine run a few minutes with the coolant cap off as the system purges air from itself automatically - you'll see bubbling in the coolant container as the level drops when air is purged. Top off with pain water and cap the system, check level the next day.
Saturn Ion 2003 Transmission Drain Plug Location ericksaturn Ion General 8 01-01-2012 02:13 PM
AC Drain Location 94 SL2 ROFL SQUAD S-Series Tech 7 11-12-2010 11:02 PM
2002 Saturn Vue ECM location lgates3522 Vue Tech 5 11-12-2010 10:34 PM
PCM B Fuse - Exact Location Please Pitcher S-Series Tech 4 08-19-2010 12:32 AM
93SL2 Front Lamp Splice Pack for grounds, left front - exact location? 93goldsl2 S-Series Tech 2 11-23-2005 04:48 PM
