Old 01-23-2014, 02:07 AM   #1
clownnasty
clownnasty is on a distinguished road
Question all wheel disk brakes conversion
ok so i have a 98 saturn sl wagon and i have a donner 94 saturn and it has full disk brakes on it and i want to put them on my wagon can it be done by simply just pulling them off and putting them on or is there a lot more involved then im thinking i have the whole car so if i have to pull all to swap i can any info would be great thanks
Add to clownnasty's Reputation
Rate the quality of this post and help clownnasty reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
clownnasty is offline   Reply With Quote
Old 01-23-2014, 02:33 AM   #2
anmasher
anmasher's Avatar
Default Re: all wheel disk brakes conversion
I think everything will work except the parking brake cable. RockAuto should have one that will work (you'll need a 98 SW cable for a 4 wheel disc car) if you don't want to dig out a junkyard cable.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-23-2014, 10:54 AM   #3
SL19302
SL19302's Avatar
2002 SL1
Everything is bolt on and go, The only pain is the parking brake cables, You need a set from a 96-98 SL/SW, A salvage yard is where I got mine....
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 01-23-2014, 01:50 PM   #4
clownnasty
ok thanks so i wont have to switch out master cylinders noting like that?
Old 01-23-2014, 11:49 PM   #5
SL19302
SL19302's Avatar
2002 SL1
No, Everything up front is the same.
CHECK YOUR OIL!
Old 01-24-2014, 05:40 PM   #6
DonP1
DonP1 has a spectacular aura aboutDonP1 has a spectacular aura aboutDonP1 has a spectacular aura about
How hard is it to do a rear disk brake conversion if you don't have a donor?
What parts would you need?
My 1997 SL2 (RIP) have 4 wheel disc. My new 99 SL2 has rear drums.
Thanks.
Add to DonP1's Reputation
Rate the quality of this post and help DonP1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DonP1 is offline   Reply With Quote
Old 01-24-2014, 05:59 PM   #7
Ramics
Ramics is on a distinguished road
Ramics's Avatar
Your going to need the caliper's to start with. That's the most expensive part of all.
Also:
Emergency Brake Cables. (2) Same length for each.
Brake Hoses (Optional)
Hub's (depending on condition of ones installed right now)
Rotors
Brake Pads
Dust Shields (You won't be able to find these without a donor)
Go to Rock Auto here:
http://www.rockauto.com/catalog/raframecatalog.php
for the best prices.
I just did this last weekend and the brakes are more solid now.
Read this for more info:
http://www.saturnfans.com/forums/arc.../t-147083.html
Add to Ramics's Reputation
Rate the quality of this post and help Ramics reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ramics is offline   Reply With Quote
Old 01-24-2014, 11:13 PM   #8
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
It is a nice upgrade. I'd recommend if you have the cash to also upgrade the lines to SS and the pads. The largest benefit to the rear discs is pad selection.
Doing a JY upgrade is pretty darn cheap. If you get good pulls it will be far less than new and with the difference in price you can do both better pads and lines.
I would recommend buying new rotors. They are cheap and JY rotors tend to be rusty. and aren't worth machining.
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline   Reply With Quote
Old 01-25-2014, 11:30 AM   #9
Ramics
Ramics's Avatar
Here are some photos of the drum to rear disc conversion.
They are in order.
I used a wire brush and brake cleaner after removing the original hubs.
Also painted the dust shields (junk yard item) as well as the calipers.
I tapped the drum around the diameter to get it off. Then removed the springs and hardware of the drum setup as well as the hoses and cables.
After loosening the fasteners of the hub, I also tapped them with a hammer and same piece of short 2 x 4 wood piece to remove.
Please let me know if you have any questions.
Old 01-25-2014, 11:42 AM   #10
Ramics
Ramics's Avatar
Also. Make sure to install a new set of emergency brake cables as the ones stock with the drum brake setup will not work.
See here..
http://www.saturnfans.com/forums/sho...d.php?t=197491
This will take care of your parking brake cable (aka emergency brake cable) installation..
Best Wishes!!
Old 01-25-2014, 12:08 PM   #11
Ramics
Ramics's Avatar
This is how it will look when you are finished.
Old 01-25-2014, 12:38 PM   #12
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Nice write up. I have two 3rd gen SC2s that I would like to convert.
Is replacing the hub/bearing required? Or just something you decided to do?
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 01-25-2014, 12:45 PM   #13
Ramics
Ramics's Avatar
Mine were still in good shape. I just wanted new ones to make the setup "look new". I put the used ones away in case I need them in them future.
Just make sure to clean them up as well as the bore prior to installation.
Old 01-25-2014, 12:47 PM   #14
caveeagle
caveeagle's Avatar
ok. thats what I thoughts. One of my SC2 cars came with ABS. I thought there might be some conversion issue getting those hubs to work with the early rear disks.
Also are there any differences on the early rear disk set-ups? can you just pick out any year S-series that had rear disks?
Mark
Old 01-25-2014, 12:56 PM   #15
Ramics
Ramics's Avatar
My car is a '96. The doner was a '98.
I think '98 was the last year for the rear discs for the S-Series as an option. Up until '98 Im thinking that all the ABS Saturns had the rear disc brake set-up.
They should all interchange between model years.
The only specific item your going to need is the parking (emergency brake) cables as they are different for different years and wheel base differences.
Old 01-25-2014, 01:02 PM   #16
caveeagle
caveeagle's Avatar
I knew that about the cables. I was planning to either order new cables, or find out which year/model had the same wheel base as the 3rd gen SC cars and hunt for those in the yards. Since I have two identicle cars, I can save some effort on research (anyway). And both cars are due for a rear brake job. So I would much rather put the effort into a disk conversion vs fooling around with drum brakes. Comming from a background working on vintage mustangs, I am totally through with working on drum brakes.
Mark
Old 01-25-2014, 01:07 PM   #17
Ramics
Ramics's Avatar
It will be worth it! Let me know if you have any trouble with the installation..
Old 02-11-2014, 06:34 AM   #18
1ron Duke
1ron Duke is on a distinguished road
I'm doing a complete brake upgrade on my SL1. found some great rotors on autoanything
'01 SL1 SOHC 5speed, super clean.
Add to 1ron Duke's Reputation
Rate the quality of this post and help 1ron Duke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1ron Duke is offline   Reply With Quote
Old 02-11-2014, 10:51 AM   #19
'97 SL1 w/ABS = drum rear brakes. I believe it was determined that in '95 or '96 the SOHC's started getting drums no matter what so your best bet is looking at DOHC's with ABS.
Old 02-11-2014, 11:58 AM   #20
SL19302
SL19302's Avatar
2002 SL1
Also you will need rear park brake cables from a 96-88 Disc equipped car you can get these pretty cheap out of the junkyard. All ABS Saturns didnt come with Disc, 98 WAS the last year for the option.
CHECK YOUR OIL!
rear disk conversion wheel bearing ? kingkevin8 S-Series General 2 06-28-2011 10:56 PM
Add on to hydraulics for 4 wheel disk conversion. Mgg4591 S-Series Mods 3 01-21-2011 09:33 PM
rear wheel disk brakes proneto911 S-Series Mods 34 07-26-2009 02:47 PM
4 wheel disk brakes on 96 SL2 groingo S-Series General 4 04-22-2009 05:39 PM
Rear Wheel Disk Brakes for VUE??? blkVUEredline Vue General 24 05-16-2005 01:09 PM
