Old 10-11-2013, 07:04 PM   #1
mLrR.19
mLrR.19 is on a distinguished road
Default anyone know how many lbs i can put of turbo to engine 1.9 of sc2 96??
Ah anyone had this experience?
Add to mLrR.19's Reputation
Rate the quality of this post and help mLrR.19 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mLrR.19 is offline   Reply With Quote
Old 10-11-2013, 07:18 PM   #2
billysvue
Default Re: anyone know how many lbs i can put of turbo to engine 1.9 of sc2 96??
All depends on many different factors:
engine fresh or a dud?
tuned properly or choking for fuel?
any aftermarket parts?
nitrous?
balancing/blueprinting/engine rebuilt?
stock copmpression or lowered?
any forged parts?
what fuel octane?
knowledgable tuner?
that's just for starters, imo......
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 10-11-2013, 07:23 PM   #3
anmasher
anmasher's Avatar
Welcome to SaturnFans!
On a stock engine? Basically 0.
If you are not a one-post-wonder head over to SixthSphere and read everyday for about 3 months. Then create an account and go from there. Boosting a Saturn isn't for the faint of heart.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-11-2013, 07:26 PM   #4
billysvue
Probably be cheaper to buy a boosted VW gasser or a 1997-2001 SUper DUty Ford p/u. ANd either or would work much better.
'17 Suby Forester
Old 10-11-2013, 08:20 PM   #5
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
With good everything, 4 or 5 is probably pretty reasonable. But fuel control is the biggest issue. Most NA engines in good shape can handle about 4 or 5 pounds without any drama.
But I'd advise you as someone else already has, just go buy a turbo car. There are lots of great cars from the 80's and 90's that already have turbos. Cars with stock turbos tend to have very well setup engines and can take much more boost that they left the factory with.
For the cost of turboing a Saturn decently, you can buy a car that is turboed from the factory. In many ways this is the best solution, but I think the most outstanding part of this idea is that you get to into into turbocharging by seeing how a car manufacture did it. Crawling through a factory turboed car will teach you a lot about what you need to know if you ever want to turbo a NA car in the future.
As I said there are lots of cheap turbo cars out there to sharpen your teeth on. Old Dodge and Mitsubishi cars can be for little.
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline   Reply With Quote
Old 10-11-2013, 09:36 PM   #6
I vote for starting out with a full 20psi and see how long it lasts...but don't plan on much longer than 10 minutes without spending more than a modified '90's AWD Eclipse goes for.
Old 10-11-2013, 09:36 PM   #7
SL19302
SL19302's Avatar
2002 SL1
Saturn Engines were not built for performance, Racing is not in the breed its advised to keep the RPMs under 3 grand to reduce oil consumption, Boosting a Saturn 1.9 and running it at 5 grand all the time is a bad idea, It will put alot of stress on the rotating assembly and use oil like mad, dont do it.
Add to SL19302's Reputation
Old 10-11-2013, 10:09 PM   #8
FullNelson13
FullNelson13 is on a distinguished road
join up on sixthsphere to get some turbo pointers. Plenty of boosted turds on there. If you have the knowledge and the cash its plenty safe to boost.
Add to FullNelson13's Reputation
Rate the quality of this post and help FullNelson13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FullNelson13 is offline   Reply With Quote
Old 10-11-2013, 11:44 PM   #9
Nicktheviperman
Nicktheviperman is on a distinguished road
Nicktheviperman's Avatar
2002 SL1
unless u have alot of time and money i wouldnt do it and thats just asking for something to break and if u do end up doing it i wouldnt go over 6 psi there is a turbo kit out there go on wikisaturn and there should be a link not sure if the link is still active
hmmmmmmmmm
Add to Nicktheviperman's Reputation
Rate the quality of this post and help Nicktheviperman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nicktheviperman is offline   Reply With Quote
Old 10-12-2013, 01:44 AM   #10
amazinghl
My GLH likes around 20psi.
My CSX likes around 17psi.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 10-13-2013, 05:05 PM   #11
FullNelson13
There is a build running 15lbs right now. So I don't think you are aware that you aren't giving good advice. But, of course if you use a weak ass turbo kit you can't do anything.
Old 10-14-2013, 06:00 PM   #12
Recycled Saturn
Recycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura about
Recycled Saturn's Avatar
100psi
1998 SL2-AMR Strut Bar, AEM CAI, and 119,XXX
Add to Recycled Saturn's Reputation
Rate the quality of this post and help Recycled Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Recycled Saturn is offline   Reply With Quote
Old 10-14-2013, 06:26 PM   #13
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
It can handle all of the psi. Go bawls out.
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 10-24-2013, 06:31 PM   #14
BobtheTechguy
BobtheTechguy is on a distinguished road
Just get something like a Volvo s60 2.4T its an Inline 5 cylinder turbo and fun as hell to drive.
Add to BobtheTechguy's Reputation
Rate the quality of this post and help BobtheTechguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobtheTechguy is offline   Reply With Quote
Old 10-24-2013, 08:20 PM   #15
Recycled Saturn
If they can do it on Fast and Furious, then my Saturn can definitely do it
turbo on stock engine rv93 S-Series Mods 51 03-13-2013 01:16 PM
1.9L TURBO Diesel Engine on EBAY in USA Articwhite2008 Astra General 15 01-26-2010 08:49 PM
Turbo? engine work? 03 ion KS&Dracing Ion Mods 11 08-24-2008 11:24 PM
Looking for new engine & turbo 97sleeper S-Series Mods 2 06-08-2006 05:18 PM
