Old 10-05-2013, 10:58 AM   #1
jjbendo
jjbendo has a spectacular aura aboutjjbendo has a spectacular aura about
Default tires
A friend gave me 4 tires, 205/60-15 I know this is not the specified size, with more than 50% life left. I did a search on tire sizes to see if these would fit. I saw lots of info, but not on this tire size. I just would like to know if they will fit with out rubbing anything.
1995 SL2, 150,000 miles, replaced clutch and struts 2 yrs ago.
John B
1995 SL2, 5-spd, 135,000 mi
Add to jjbendo's Reputation
Rate the quality of this post and help jjbendo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjbendo is offline   Reply With Quote
Old 10-05-2013, 11:50 AM   #2
Default Re: tires
205/50's fit fine on stock alloy's, tons of fun. I imagine that a 60 series will float/flex so much as to not be any fun at all. Worth using if they're free, went a winter with free studded 195/70R14's that I got for free (otherwise they weren't worth it on a S-Series).
Tire & rim mix-match: http://www.rimsntires.com/specs.jsp
stock wheel info (assuming stock 15" wheels) needed for that site:
15" wheel
6" wide
+50mm offset
not needed but useful:
4x100 lug pattern
57.1mm hub
Old 10-05-2013, 12:06 PM   #3
ehunter
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
Default Re: tires
You do know that they will affect your speedometer, odometer and thus your mpg calculations right? Not a problem just as long as you know it.
Add to ehunter's Reputation
Old 10-05-2013, 02:58 PM   #4
jjbendo
Default Re: tires
thanks everyone and thanks for the reminder on affects to my speedometer, odometer and thus your mpg calculations right
John B
Old 10-05-2013, 03:16 PM   #5
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Re: tires
I've got them on the front with a 5mm spacer.
Don't know if they fit without the spacer, never tried, but planning to try soon...
On the back they fit no problem.
Ride is radically different, car just wants to go straight...
20 mm more rubber than the 185's,
turning the wheel takes a little more effort,
speedo is not off by much, maybe 2-4 mph...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Tires: Best Replacement Tires for 2000 Saturn SL harryrs S-Series General 18 07-12-2010 02:03 AM
Tires: Best Replacement Tires for 2000 Saturn SL harryrs L-Series General 4 06-24-2010 11:59 PM
Trade: Polished 17's w/tires for 16's w/tires snobrdrdan Ion Red Line 5 09-19-2007 08:39 PM
Performance Tires - Bigger Wheels thinner tires better? Chris93SL2 Mods and Performance 14 04-16-2003 04:03 PM
Winter tires cheap performance tires? Sattyinsnow Miscellaneous Tech 5 03-31-2003 03:04 PM
