Old 12-18-2012, 06:48 PM   #1
tgggd86
tgggd86 is on a distinguished road
tgggd86's Avatar
Default High Idle after Throttle Body cleaning
Problem: Upon starting up my car (97 Saturn SC2) after I cleaned the TB, it begins to idle around 2700 then slowly climbs down. Wasn't doing this before I cleaned it. It'll eventually go back down to 1200 after a few seconds. But will repeat the same thing every time I restart the car.
Possible Cause: I'm 99% sure that it's the Idle control solenoid, mainly because it was having a hard time going in, (I figured it was because of the O-ring) so I compressed the little brass part with a spring wrapped around it a little bit.
So I'm guessing what I did caused the problem. Now will the car eventually correct this by adjusting the solenoid, or do I have to go back and adjust the solenoid manual and "fix" what I "broke"?
Thanks!
Add to tgggd86's Reputation
Rate the quality of this post and help tgggd86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgggd86 is offline   Reply With Quote
Old 12-19-2012, 03:41 AM   #2
tgggd86
tgggd86's Avatar
Default Re: High Idle after Throttle Body cleaning
Well looks like it fixed itself after a 15 mile drive.
Old 12-19-2012, 08:21 PM   #3
anmasher
anmasher's Avatar
I would suggest resetting the PCM (unplug the battery for awhile), that seemed to solve my idling issues after cleaning the throttle body. But as you've found out, it might re-learn whatever it needs to without resetting it.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
high idle and SES after throttle body + EGR cleaning Troy35 S-Series General 25 02-26-2011 11:09 PM
Idle oddity after cleaning throttle body aa4lr S-Series Tech 15 11-30-2009 07:20 PM
high idle after cleaning throttle body shur35 L-Series General 2 04-05-2009 03:15 PM
2001 SL1 high idle after cleaning Throttle Body rickystarshine S-Series Tech 6 11-19-2006 09:33 AM
Throttle Body and Idle Air Control Valve Cleaning Heartbeat - '95 SL2 Miscellaneous Tech 6 10-05-2001 02:53 AM
