Old 10-18-2012, 12:02 PM   #1
Keblar
Keblar is on a distinguished road
Wrench Replace Axle Seal While Replacing Axle?
Is it silly to NOT replace the seal on the Driver side while I'm replacing the Axle if it's NOT leaking? Getting an old seal out seems to be a sticking point for some, and I'd rather not bring this into the equation if I don't have to. My repair window is small enough, and I'd rather just get the old axle off and get the new one on.
02 SL2 ~250k miles
Thanks!
Add to Keblar's Reputation
Rate the quality of this post and help Keblar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keblar is offline   Reply With Quote
Old 10-18-2012, 03:35 PM   #2
RobertGary1
Default Re: Replace Axle Seal While Replacing Axle?
If the transaxle seal isn't leaking I leave it alone. It's not the end of the world if you have to do it later anyway. Getting the seal out is easy with a hooked seal pulled. Installing the new one is tricky. Go to the parts store and get a small exhaust pipe piece of the precise diameter, place a block of wood against it and tap with hammer. The new seal must be tapped evenly 360 degress around or it will bend and leak. You can't just tap on the seal itself.
Why does my axle seal keep on leaking? turbobuick33 S-Series Tech 8 07-16-2008 01:18 PM
Do I have the right axle seal? turbobuick33 S-Series Tech 10 07-08-2008 08:14 PM
axle seal removal? 92[SL2] S-Series Tech 5 12-22-2006 10:45 AM
Axle Seal SL2Dreams S-Series Tech 5 09-19-2005 08:50 AM
Axle seal sc2095 S-Series Tech 1 05-13-2005 09:58 PM
