Old 07-12-2011, 08:02 PM   #1
lodingi
lodingi is on a distinguished road
Default A/C stopped working
Hello Saturn Fans. I have an 03 FWD V6 with 210,000 miles. The a/c stopped working recently. I brought the vehicle to a mechanic for repair. According to the mechanic, he wasn't sure of the problem.
He did feel the compressor was not the culprit. I asked how he came to this conclusion considering the compressor doesn't turn on. He mentioned coloration and general condition of the compressor. I've never heard this before, but I am no a mechanic so I guess it's possible.
He then stated he wasn't comfortable just swapping parts until it started working again. He then suggested I take the Vue to a mechanic with Saturn experience.
Are there any trouble shooting steps I can take to diagnose the problem? I would greatly appreciate your input. Thanks.
2003 Vue 3.0L V6 FWD - 167K
Add to lodingi's Reputation
Rate the quality of this post and help lodingi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lodingi is offline   Reply With Quote
Old 07-12-2011, 09:33 PM   #2
Default Re: A/C stopped working
This mechanic may be one of a few to turn down work. Not knowing a/c systems would be one reason. A healthy respect for accepting limits of knowledge can keep mechanics honest and repeat customers. To suggest referring to another shop promotes better business.
Your a/c system can't use a short cut like the S-series with a wire jumper across the pressure switch connector to enable compressor operation; your pressure switch uses a transducer that's a little more sophisticated in detecting pressures that vary low output voltages between 0.1-5v DC as input signals to the ecm to determine whether to allow compressor operation or not. With a dead compressor, its most likely a loss of refrigerant after so many years of reliable use. 210k miles is a lot of bumpy roads to rattle a system loose. The best way to find a leak without resorting to refilling is to simply spend the time to inspect the entire system for dye or oil leaking from anywhere. 98% of the entire a/c system is in the engine area, 2% is for the expansion valve and evaporator coil on and behind the firewall. Inspect in, around, under and from the sides to check for greenish yellow fluorescent dye that can be seen in shaded daylight or at night with a small uv light. Even loose service valve caps leak if not tightened.
It only takes 0.5lb of R134a to overcome the pressure switch to allow compressor operation if the clutch coil or the main a/c fuse isn't blown.
Old 07-15-2011, 10:24 AM   #3
lodingi
Thanks for the info. I will inspect the car thoroughly this weekend. I believe the mechanic tried to fill the unit with coolant and it wouldn't take. Not sure what that means.
I will also call the mechanic and ask again. I want to make sure I am expressing his comments correctly. Thanks again.
Old 07-17-2011, 01:22 PM   #4
lodingi
I spoke to the mechanic. He said he lacked the computerized equipment necessary to diagnose an electrical porblem. He does in fact believe my problem is electric related & not mechanical.
Thanks again for your help.
Old 07-17-2011, 03:22 PM   #5
Well, you can check the easy stuff; a/c fuse, relay, and power to the compressor.
Old 07-24-2011, 10:16 AM   #6
lodingi
I brought my Vue to another shop. This shop was recommended by my mechanic. He diagnosed the problem. It was a faulty connection at the pressure switch. He repaired the connection, evac & recharge the system, & all is well.
Kudos to my mechanic for doing the right thing. I would neever hesitate having my car serviced or repaired by him.
Thanks for your help.
Old 07-24-2011, 10:28 AM   #7
far2grumpy
far2grumpy's Avatar
Congratulations ... you are fortunate to have a reliable mechanic, who not only recognized his limitations - but did the right thing by referring you to a competent A/C shop.
This is a good story!!!
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
AC stopped working outdoorman S-Series Tech 14 05-27-2011 03:34 PM
AC stopped working cboss S-Series General 8 04-05-2010 05:06 PM
AC stopped working jonnycube S-Series General 14 07-25-2009 07:56 PM
Key FOB stopped working SpohnSoftware S-Series Tech 0 05-27-2009 09:28 PM
A/C not working when stopped Juncti S-Series General 17 09-18-2004 06:22 AM
