Old 05-10-2011, 10:31 AM   #1
Hagane
Hagane is on a distinguished road
Hagane's Avatar
2000 SL2
Default 2000 SL2 with no-start situation, resolved. Now running rough.
Flooded my engine with water, cleared it out, cleaned plugs, drained and replaced oil. She's running with high rpms, (1500 while idling) and running rough while idling. A little bit of sputtering, seeming like she's going to die on me. The air intake filter was clogged with water, so I'm assuming there might be debris on the throttle valve, as well as other sensors attached/involved.
Assuming this is so, I am going to clean the associated parts as per Richpin's instructions. I'm thinking to clean the EGR valve out as well. The thing I'm not all to familiar with is the location of the TB on my 2000 SL2 MPFI engine. Is it at the very end of the air intake duct? I'm going to try to take pics and put them up, very soon. But, would appreciate any input asap.
Add to Hagane's Reputation
Rate the quality of this post and help Hagane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hagane is offline   Reply With Quote
Old 05-10-2011, 11:56 AM   #2
Hagane
Hagane's Avatar
2000 SL2
Default Re: 2000 SL2 with no-start situation, resolved. Now running rough.
I believe I just answered my own question. I didn't notice the the throttle cable coming up onto the switch earlier. Can't post pics directly, apparently.... :/
Old 05-10-2011, 12:00 PM   #3
Try the "attachment" feature; it's the "paper clip" icon above the editor window.
Add to madpogue's Reputation
Old 05-12-2011, 09:33 PM   #4
Hagane
Hagane's Avatar
2000 SL2
Cleaned up the IAC, as well as the throttle body/butterfly. It was still running high, but took readings in the 20K range on the IAC pins, and they read at 0.040. Replaced that, and she's running quieter than a cat's backend.
2000 SL2 with no-start situation. Need extra brains on this!!! Hagane S-Series Tech 8 05-08-2011 09:16 PM
93 SL2 running rough, now wont start mudboy S-Series Tech 10 08-23-2010 11:05 AM
2000 SL Hesitation Rough Running. Ignition Module? harryrs L-Series Tech 3 06-12-2009 05:27 PM
2000 SL1 runs rough after cold start jsmith7290 S-Series Tech 8 12-27-2008 11:36 PM
'94sc1-awful Start/rough Running MARKEDV1 S-Series General 3 12-08-2005 03:12 PM
