Old 07-09-2009, 08:30 PM   #1
SL2Ghost42
SL2Ghost42 is on a distinguished road
SL2Ghost42's Avatar
2000 SL2
2004 VUE 2.4L
Default stock air intake - all models use the same?
The regular stock air intake system, the part that connects the engine to the air filter and holds the air filter, is the 2nd gen and 3rd gen air intakes use the same exact air intake system? I need to replace mine completely (due to the fact that it is now illegal in missouri to have a short ram/cold air intake on your car, mine didn't pass Safety with it on this year!) and I don't have the original. I may have a replacement available but it's from a 2nd gen and I have, obviously, a 3rd gen.
Thanks!
2000 SL2 107,000 "Little Saturn" - Daily Driver
2004 Vue 125,000 "The Vue" - Work Vehicle
Add to SL2Ghost42's Reputation
Rate the quality of this post and help SL2Ghost42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2Ghost42 is offline   Reply With Quote
Old 07-09-2009, 09:25 PM   #2
Default Re: stock air intake - all models use the same?
Alas, your gen-3 car has that centrally-mounted "down-draft" throttle body and shorter intake manifold, so the intake tubing from the air box is longer. Find a photo in our gallery of a gen-2 DOHC engine and you'll see; they have a bigger intake manifold, and the TB on the driver's side of the engine, so the tubing is shorter. The air box itself is probably the same. You might be able to fab up some extension tubing to fit between the gen-2 intake tubing and the gen-3 TB, but Mr./Ms. Inspector might not like what s/he sees.
Add to madpogue's Reputation
Old 07-09-2009, 11:02 PM   #3
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
If that doesn't work out you should be able to get an 00-02 for a couple bucks at a local salvage yard. If you call around you should be able to find one easy.
Perhaps post a wanted listing on craigslist?
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Old 07-10-2009, 01:07 AM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
You can get the intake from any '00-'02 DOHC model - SC2, SL2, or SW2.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Short Ram Intake or Cold Air Intake? RDKamikaze S-Series Mods 50 12-24-2010 12:29 PM
Short Ram Intake vs Cold Air Intake Saturn Tuner S-Series Mods 29 01-30-2010 09:54 AM
Cold air intake removing stock air intake acwild S-Series Mods 2 03-26-2006 01:18 PM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
WTB: Stock air intake stuff redblazerx Classifieds 4 05-14-2004 07:24 PM
