Old 10-21-2008, 03:06 AM   #1
prabhakarglv
prabhakarglv is on a distinguished road
prabhakarglv's Avatar
Wrench How to install Block Heater for Saturn SL-2 1999 Model, TwinCam Engine, 4-Door Sedan
Hi,
I feel proud to join in Saturn Community. I'm a Physiotherapist and from a small community called Whitecourt, province of Alberta and in Canada. Currently I owned Saturn SL-2, 1999 Model car. I just bought a Block Heater (Saturn OEM) for my vehicle and would like to install that part. It's just looking like a immersible water heater and with a bolt and cord. However I would appreciate if any one can give me the clear instructions in regard to fix that product in my car.
Thank you,
Regards,
PUBBY.
Add to prabhakarglv's Reputation
Rate the quality of this post and help prabhakarglv reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
prabhakarglv is offline   Reply With Quote
Old 10-21-2008, 10:55 AM   #2
Default Re: How to install Block Heater for Saturn SL-2 1999 Model, TwinCam Engine, 4-Door Se
Didn't you get he instruction sheet with it?
The tab on the end opposite the bolt hole fits under a very slight bulge on the bottom of the head and the other end bolts into the hole in the block by the dip stick tube. the block should be cleaned off before mounting and the heater must fit tight against the block. If you need pictures or a copy of the instructions, post back and I will copy them for you.
Old 10-21-2008, 11:07 AM   #3
prabhakarglv
Thumbs Up Re: How to install Block Heater for Saturn SL-2 1999 Model, TwinCam Engine, 4-Door Se
Hi OldNuc, I really thank you for your reply. I would appreciate if you could send the installation pictures for to fix the block heater in my car.
Thank you once again,
Regards,
Pubby.
Old 10-21-2008, 11:16 AM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
Regards,
Pubby.
It really pretty simple to do.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 10-21-2008, 02:13 PM   #5
I wish I had that on a DVD...
That is how it goes on. Clean block, place against block and slide up so tab contacts the tab, install bolt. Check that the element contacts the block. Connect and route electric wiring over to behind left headlight. Clip to the radiator support.
On your engine there is a very small bump that he top of the heater element fits behind, no hole to stick it into. You can feel it, barely.
Old 10-22-2008, 01:22 AM   #6
prabhakarglv
I really appreciate you guys for saving me 100 bucks atleast. It's really worked. Thank you once again.
Regards,
Prabhakar.
Old 10-22-2008, 11:36 AM   #7
dhymers
dhymers is on a distinguished road
dhymers's Avatar
1993 SW2
Where can I get one of these ?
Dealerships stock them ?
In Arizona, stuff doesn't rust, it bakes.
Add to dhymers's Reputation
Rate the quality of this post and help dhymers reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dhymers is offline   Reply With Quote
Old 10-22-2008, 11:51 AM   #8
you get the RIGHT part number for your car and order it from Get Saturn Parts. It costs about $80.00. If you go to the dealer the price will make your heart stop. You can not find the thing by description on the Get Saturn parts catalog and there are 2 different designs.
You actually might find it though, its hidden under HVAC.
If you still want one, post back and i will look up the part number for you.
Old 10-22-2008, 12:00 PM   #9
92SC2
92SC2 is on a distinguished road
Why do you want a block heater if you're in AZ?
Add to 92SC2's Reputation
Rate the quality of this post and help 92SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92SC2 is offline   Reply With Quote
Old 10-24-2008, 06:10 PM   #10
Satsational
Satsational is on a distinguished road
1996 SL1
I just bought one of these for my SL1 after reading all of the posts about how horrid cold starts are on these cars (already with their oil issues). Figure it will help with a few things in sub-ZERO weather like starting the car (lol), instant warm heater air, better gas mileage in the winter, and less wear and tear on the engine.
Not that expensive either
1996 SL1 5spd
2001 Grand Prix GTP
2008 G5 SE
www.focusfast.com
Add to Satsational's Reputation
Rate the quality of this post and help Satsational reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Satsational is offline   Reply With Quote
Old 10-24-2008, 06:44 PM   #11
Buy a timer and turn the heater on about 1 1/2 hour before startup. they do make a difference. Well worth the cost.
Old 10-24-2008, 08:04 PM   #12
Satsational
1996 SL1
never thought about the timer, thanks!
1996 SL1 5spd
2001 Grand Prix GTP
2008 G5 SE
www.focusfast.com
Old 11-03-2012, 04:38 PM   #13
haese1956
haese1956 is on a distinguished road
2001 sc3 which has been a garage queen its entire life but now it has to live outside (we've become garageless... Is the installation this simple on my Saturn also? (At least it sounds easy) I'll be on the ground with the car on jack stands. I'm also thinking about a magnetic oil pan heater. Winter is coming fast here in Alaska
Add to haese1956's Reputation
Rate the quality of this post and help haese1956 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
haese1956 is offline   Reply With Quote
Old 11-03-2012, 06:12 PM   #14
Bottom of pan is ribbed so magnetic heater is a fail. The 98 and up block heater takes about 15 minutes to install from above.
Old 11-03-2012, 06:19 PM   #15
haese1956
"From above" like with the hood open? Or like the post above ? hopefully it will come with some decent instructions. I noted the ribbed pan figured that would reduce the effectiveness ...
Old 11-03-2012, 07:27 PM   #16
The block heater does come with instructions and it sits right next to the dip stick tube. The hard part is finding the hole in the head.
Saturn OEM Parts Source
GM Parts Giant- http://www.gmpartsgiant.com/
GM Parts Direct- http://www.gmpartsdirect.com/
Get Saturn Parts- http://www.trademotion.com/splash/in...?siteid=214643
GMparts4U.com- http://gmparts4u.com/
The part number you want is 21008372 find the lowest price that will ship you one.
Old 11-04-2012, 09:12 PM   #17
laser3kw
laser3kw will become famous soon enough
2000 SC1
just ordered mine
GM Parts Direct $58 + shipping = $74
I think their registration was f *** ing with me because I unchecked the "receive email offers" box. I had to re do the entire form a few times because it didn't like something.
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
Old 11-04-2012, 11:09 PM   #18
Spaghettiohead
Spaghettiohead is on a distinguished road
Those pan-heaters work great as well. Installed one on my Corolla for NH winters a few years ago. Sand the bottom of the pan, mix up some Steel Stick to stick in the grooves, sand again to a flat surface, and mount the heater. Use in conjunction with a block heater and you're golden!
Add to Spaghettiohead's Reputation
Rate the quality of this post and help Spaghettiohead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spaghettiohead is offline   Reply With Quote
Old 11-05-2012, 12:38 AM   #19
bumpdraft
bumpdraft's Avatar
1998 SW2
I cleaned the aluminum engine block with a wire cup on a drill.
^engine out of car
After I installed this one, I bought one for my dad. I swear it took me 10 minutes to get the heater mounting tab in the block correctly.
After a few minutes of fumbling, you'll want an inspection mirror to assure yourself there really is a slot in the block (there is)
Add to bumpdraft's Reputation
Old 10-07-2013, 12:49 PM   #20
Spaghettiohead
Thread revive!
Just ordered one from the dealer in town, but they say it doesn't come with the wiring/plug. Where do I find that?
Install the '98+ block heater on a '96 SL2 rglr S-Series Tech 1 07-17-2010 05:19 PM
Saturn S-Series Engine Block Heater ? 2NDSOUT S-Series General 3 02-05-2009 10:51 AM
Block heater install help! 92 Coupe S-Series Tech 0 12-24-2005 08:16 PM
Block Heater install. VWman S-Series Tech 4 11-28-2005 11:09 PM
late model engine block swap EzDi Miscellaneous Tech 2 08-14-2003 08:01 PM
