Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 09-26-2007, 05:50 PM   #1
Xboxer
Xboxer is on a distinguished road
2004 VUE Red Line
Default Survey: Does YOUR RL have rear camber?
Ok, sorry I've posted a similar topic a while ago. However, I didn't get much response.
I am having a bad time with my tires (rear) being shredded over a short time period. In fact my case is with Saturn Corporate now.
However, while I wait, my tires are at the mercy of potentially wrong camber (which service claims is "probably" normal).
My questions to you RL owners:
1) Do you have really noticeable rear camber? ie) does it look like your rear end is overloaded and the wheels are bent out?(Mine are evn when aligned, and under no load - appears to be a few degrees.)
2) Do you have very straight camber? (Or mostly vertical)
3) Is their a correlation between the recall from a few years ago - if you got it at all( the suspension adjustment to avoid rollover) and your present camber?
Thanks for humoring me on this. Its been really stressful on us with the cost of these tires, and the whole rear alignment fiasco we went through.
PS: Perhaps I could post pics from the rear end so you can see for yourselves...?
Add to Xboxer's Reputation
Rate the quality of this post and help Xboxer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Xboxer is offline   Reply With Quote
Old 09-26-2007, 09:22 PM   #2
D C
D C is on a distinguished road
D C's Avatar
Default Re: Survey: Does YOUR RL have rear camber?
Measured camber is about -0.7deg per side. There should be no problems with adjustment before or after the recall.
Add to D C's Reputation
Rate the quality of this post and help D C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
D C is offline   Reply With Quote
Old 09-27-2007, 08:56 AM   #3
drivehard
drivehard is on a distinguished road
2004 VUE Red Line
There are MUCH cheaper alternative sized tires out there for you to use on the stock Redline rims. View the alternative tire size thread or PM me for details.
Yes, my RL has rear camber. I have not noticed any unusual tire wear from it.
Add to drivehard's Reputation
Rate the quality of this post and help drivehard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
drivehard is offline   Reply With Quote
Old 09-27-2007, 12:41 PM   #4
bassplayrr
bassplayrr is on a distinguished road
bassplayrr's Avatar
2005 VUE Red Line
Camber should have little to no impact on wear assuming toe is 0, which it should be on a Vue. I ran 2+ degrees of negative camber on all four corners in my WRX for over a year and had no real wear problems because my toe was always 0. Toe is going to be the more important number to look at if you're shredding tires.
Negative camber in the rear is very common on most modern cars as it leads to a tendency to understeer. The automakers view understeer as safer for the average driver than oversteer.
www.aolights.com
Add to bassplayrr's Reputation
Rate the quality of this post and help bassplayrr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bassplayrr is offline   Reply With Quote
Old 09-27-2007, 01:28 PM   #5
Xboxer
2004 VUE Red Line
This is info I was given from the Acura Alignment shop after getting the last alignment: (why it said 4x2 is beyond me)
FOR A : Saturn 04 VUE 4x2 Red Line
REAR LEFT RIGHT
Camber -0.80 -1.33
Cross Camber 0.53
TOE -0.06 -1.18
TOTAL TOE -1.24
THRUST ANGLE 0.56
So what is TOE? The bolded text above was shown on the printout.
Do these numbers tell you why the rear tires were shredded?
Old 09-27-2007, 02:00 PM   #6
burnout
burnout's Avatar
As the camber gets more negative in our cars, the toe starts to stray from 0. Its just the way our suspension is set up.
My rear tires are shredded as of right now. I am running sprint springs that I cut with a cutoff wheel to make my car low as hell. /ghettomod
Whenever I hit a bump, I can actually feel the rear of the car scoot to one side because the rear tires toe in/out as the suspension compresses.
Needless to say, I bought some new lowering springs because these cut sprints just aren't "cutting" it.
...But it looks cool!
'13 VW CC 2.0T
'99 Volvo S70 AWD
Add to burnout's Reputation
Rate the quality of this post and help burnout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-27-2007, 04:18 PM   #7
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Camber isn't your problem. The -1.18" of toe is what is eating up your tires. That's A LOT of toe. I've seen racecars set up on the loose side with less toe than that.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 09-27-2007, 08:01 PM   #8
Xboxer
2004 VUE Red Line
Does the negative toe mean the "forward part" of the rear tires are pointing out?
My rear tire wear was excessive on the inside tread - indicative of which type of toe?
Old 09-27-2007, 09:13 PM   #9
D C
D C's Avatar
REAR LEFT RIGHT
Camber -0.80 -1.33
Cross Camber 0.53
TOE -0.06 -1.18
TOTAL TOE -1.24
THRUST ANGLE 0.56
Yes, they do. Your camber is, for the most part, fine. -.8 and -1.3 isn't a drastic difference and neither is too huge.
Toe. Now we've got something. Normally, the toe should be at about 0.08 deg toe in per side. Your left side looks a little out, but the right side is INCREDIBLY out of whack. I mean big time out. Not even remotely close to being out in left field. 1.18 deg of toe is a ton. What that gives you is a total of over 1.2 degrees of toe out instead of under 0.2 deg toe IN where it should be. Your tires are basically being dragged sideways as you drive along.
To put it in perspective, your rear tires are thinking you're cornering at a fairly decent level when you're driving straight. Think like a freeway off-ramp taken at a moderate pace. ALL THE TIME!
My guess is that your right toe link slipped at some point in time. That would also explain why your right camber is higher. Adjusting the toe link also affects camber, toe out means more negative camber, which is what you have.
Time for a full alignment and you'll be fine.
Old 09-28-2007, 12:16 AM   #10
2Lime4U
2Lime4U is on a distinguished road
2Lime4U's Avatar
2009 AURA XE
2004 VUE Red Line
We've had our RL since Jan. '04 and I've never noticed the camber issue until just about a month ago. I had no Idea if I was seeing things, or if something was wrong. Then I thought maybe it was because I've been storing
about 200#'s of stuff in back for the past 4 months while my house is for sale.
I did have the recall for the rear suspension performed, but still never noticed the tire angle. It does seem very obvious now. I used to see a lot of older BMW's like that and thought it looked pretty stupid.
My question is, By looking at the rear tires, how can I tell if the TOE is right or not? The Camber is obvious now, but what do I look for to see if the TOE is incorrect? (The tires are great, 30K on them, and perfect wear across all tires).
'04 VUE RedLine AWD V6
'07 VUE AWD V6
'03 Chevy T-Blaser EXT V8
'67 Ply. Fury III Convert. # matching 383, all original!
'83 Firebird SE w/Hi-perf. SBC
Add to 2Lime4U's Reputation
Rate the quality of this post and help 2Lime4U reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2Lime4U is offline   Reply With Quote
Old 09-09-2019, 11:57 PM   #11
TimothyC
TimothyC is on a distinguished road
my 2007 Saturn Vue redline the top of the tire is just over an inch in further than the bottom do not know what the angle is is that amount adjustable?
Add to TimothyC's Reputation
Rate the quality of this post and help TimothyC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TimothyC is offline   Reply With Quote
Camber MikeNW S-Series Tech 5 10-01-2009 06:30 PM
Rear camber bolts? TITO Vue General 4 09-22-2009 06:20 PM
Camber???? 97sc2racer S-Series General 5 07-25-2006 10:05 AM
RL Camber??? steviep831 Vue Red Line 11 02-05-2005 03:59 PM
Camber Kits? ProDarwin Miscellaneous Tech 4 03-17-2003 06:53 PM
