Old 07-11-2002, 09:43 PM   #1
JanCan
JanCan is on a distinguished road
JanCan's Avatar
2002 L-Series 3.0L Wagon
Question How do I get gum out of the floor mats?
Aaarrrgh... the LW300 is only 12 days old and I've got fresh, minty gum some kind person was nice enough to spit out in the parking lot now glued to my floor mats. I scrapped off what I could with my pocket knife. Anybody got any good recommendations?
Add to JanCan's Reputation
Rate the quality of this post and help JanCan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JanCan is offline
Old 07-11-2002, 10:09 PM   #2
wolfman
wolfman's Avatar
Default
This will sound weird but WILL work...Use creamy peanut butter! Work it into the gum and it will disolve it! Then just wash out the peanut butter with soap/water and taa daa! No more gum and no damage to the floor mat!
Add to wolfman's Reputation
wolfman is offline
Old 07-11-2002, 11:04 PM   #3
JanCan
JanCan's Avatar
Default
So would I be exchanging the minty smell with a peanut butter smell?
JanCan is offline
Old 07-12-2002, 01:26 AM   #4
medium red
medium red is on a distinguished road
Default
Use a sponge or rag to apply rubbing alcohol to the gum. This will make it brittle. Break it up with your fingers, if necessary, then brush or comb it out.
Add to medium red's Reputation
Rate the quality of this post and help medium red reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
medium red is offline
Old 07-12-2002, 06:51 AM   #5
liz00ls1
liz00ls1 is on a distinguished road
Default
The same thing happened to me about a month ago. I took a couple of ice cubes and rubbed them over the gum until it froze and then it just broke off.
Add to liz00ls1's Reputation
Rate the quality of this post and help liz00ls1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
liz00ls1 is offline
Old 07-12-2002, 08:04 AM   #6
BobL
BobL is on a distinguished road
Default
Cigarette lighter fuel. Just test on an inconspicuous place first. Lighter fuel dissolves gum.
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Old 07-12-2002, 08:06 AM   #7
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Idea
Ice cubes should do the trick. Try that first.
I had the same thing happen to me when my car was a week old. To get the gum out of the carpeting I dabbed "Goop Off" (or is it "Goof Off"?) on it until the gum came out. To get rid of the smell of the "Goop/Goof Off" I applied a bit of "Resolve" (which smells like Froot Loops a bit) carpet cleaner in that area.
David 93 SL2m is offline
Old 07-12-2002, 08:56 AM   #8
Spanky
Spanky is on a distinguished road
Spanky's Avatar
Default
I would freeze it first, and remove all you can when it is hardened. I would then remove any remaining gum with Goo Gone. I never tried Goof Off, but Goo Gone is amazing stuff and it is citrus based so it won't ruin or discolor finishes.
Add to Spanky's Reputation
Rate the quality of this post and help Spanky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spanky is offline
Old 07-12-2002, 09:08 AM   #9
RedRockerL300
RedRockerL300 is on a distinguished road
RedRockerL300's Avatar
Default
Or you can try to use the cleaners Saturn gave you (if they did when you bought it) and if it doesn't come out, they'll replace them for free. The carpet and floormats are supposed to repel all types of stains and stuff. Not sure if gum applies though. With the car only 12 days old, they just might replace the floor mat.
Add to RedRockerL300's Reputation
Rate the quality of this post and help RedRockerL300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedRockerL300 is offline
Old 07-12-2002, 11:08 AM   #10
Qlara
Qlara's Avatar
Happy
The ICE Cube trick does work wonder on gum problem....and it's water-based too, no extra smell and stain.
Add to Qlara's Reputation
Qlara is offline
Old 07-12-2002, 09:29 PM   #11
JanCan
JanCan's Avatar
Default ...And the winner is!...
Wow, thank you all for your suggestions, you're all great, tell your moms I said so.
The gum is OUT!
And the winning suggestion <drum roll, the crowd grows hushed in anticipation> is PEANUT BUTTER!
Thanks Wolfman, it worked like a charm. Didn't have smooth, used Super Chunk! Scrubbed around with an old toothbrush, the super chunks just sorted themselves out and brushed to the side. Rinsed under the tap, used some kind of orange oxy cleaner, scrubbed that in, rinsed out all the peanut butter. Can't even see where it was!
Now RedRockerL300, whom I know has exquisite taste, tells me you 'mericans get cleaners from Saturn. This is starting to P me off. First it's the credit card key I find out about, now this. How come we don't get all these perks?
JanCan is offline
Old 07-13-2002, 08:36 AM   #12
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Red Face
That is a surprise! Peanut butter has oil in it. I would not have guessed that it would have worked. (Good thing I don't slam people.... I'd have to eat my words after taking my foot out of my mouth if I did!) Now I know about peanut butter and gum stuck in carpeting! Ah, the things I learn here are great!
Old 07-13-2002, 02:10 PM   #13
trlla91sl2
trlla91sl2 is on a distinguished road
trlla91sl2's Avatar
Default
Baby oil, vaseline, wesson oil, canola oil, olive oil, These work very well, espesially the baby oil it will leave a nice baby scent
Add to trlla91sl2's Reputation
Rate the quality of this post and help trlla91sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trlla91sl2 is offline
Old 07-14-2002, 01:12 AM   #14
JanCan
JanCan's Avatar
Default
Another trick that works:
Avon "Skin-So-Soft" will remove pine tar without hurting your paint. The stuff also removes that glue from price tags, cleans anything off your hands, and works as a great bug repellent, especially blackflies. I ran out of the stuff, I don't know if they make it anymore, and now I can't find anyone who sells Avon. Weird.
JanCan is offline
Old 07-15-2002, 10:59 AM   #15
Doug_E_95_SL2
Doug_E_95_SL2 is on a distinguished road
Doug_E_95_SL2's Avatar
Default Myth
The OLD Skin So Soft has no repellant abilities.
It is an urban myth,
Mosquito and vector-borne
disease expert Dr. Jonathan Day of the University of Florida tested it and found ZERO effectiveness.
Consumer Reports tested it in 1993 and found it ineffective.
Avon reformulated SSS to include an FDA approved repellant. Now it works 100% better (but still not as well as any other repellant).
This is important stuff overseas because of malaria.
-Doug
Add to Doug_E_95_SL2's Reputation
Rate the quality of this post and help Doug_E_95_SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Doug_E_95_SL2 is offline
Old 07-15-2002, 10:17 PM   #16
JanCan
JanCan's Avatar
Default
So I was protected from blackflies by a fine myth spray.
Sorry, couldn't resist.
Nice to hear it's still available.
Now I just need to find an Avon rep.
JanCan is offline
Floor Mats LelandC Aura General 23 04-11-2008 01:33 AM
Floor Mats pepsikid Outlook General 13 11-27-2007 08:49 PM
Floor mats tmaugham S-Series General 10 05-06-2006 07:41 AM
floor mats dancingator S-Series General 11 06-25-2003 07:16 PM
Floor mats SoUp General Saturn Discussion 6 02-26-2003 11:34 AM
