Old 01-19-2020, 12:11 AM   #1
454cid
Default Anyone have pliers like this?
These came up in my "suggested" on Amazon because I've recently purchased some Christmas tree push pins, for my splash guards, on my truck. The Saturn has a lot of the push pins that have the center stud that locks the pin place.
I'm wondering if these pliers would really work well or if something better is out there.
https://www.amazon.com/Mutipurpose-D.../dp/B0722L727X
1999 Chevy K3500
Add to 454cid's Reputation
Old 01-19-2020, 01:37 AM   #2
onlinebiker
Default Re: Anyone have pliers like this?
I have two pry bars that I built out of mild steel.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 01-19-2020, 01:49 AM   #3
I don't get how all the various listings of that tool have 4+ stars, all the pins they show them being used with either have the pin head recessed under the insert or it's flush with the insert...either way they need to dig into the insert to get the pin out and they don't do that any more than a normal pair of side cutters.
They may work for the "single action" pins, but over all I'd get either these push-pin pliers or this body panel tool kit
Old 01-19-2020, 08:53 AM   #4
Try Harbor Freight for inexpensive tools.
VCX NANO
Old 01-19-2020, 09:56 AM   #5
The purpose of the hobby is to collect tools. That is only countered by the fact that I'm cheap.
Add to Waiex191's Reputation
Old 01-19-2020, 10:35 AM   #6
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
I cut a V groove into a plastic putty knife with a Dremel cut off wheel...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 01-23-2020, 02:54 AM   #7
focusofheart
Originally Posted by fetchitfido View Post
...They may work for the "single action" pins, but over all I'd get either these push-pin pliers ...
Thanks for the recommendation. It looks like it may be easier to use than the pry tool that came with the push pins I purchased.
Saturn 1998 - SL2 automatic
Hose-clamp pliers? ShawnV S-Series General 28 07-13-2012 09:32 AM
