Old 01-17-2020, 01:53 PM   #1
ticla
ticla is on a distinguished road
Default p1682 Ignition SW
hi all,
p1682
I got this code when it is very cold outside. (17 January 2020. Minus 19 C or 3 degree F)
The first starting in the morning it is just fine, motor crank good and start without delay.
I ran my car for 15-20 minutes, go shopping for 30 minutes than the first crank the car will turn but not start, I wait a bit and restart everything is ok.
I replace the ignition starting switch last year for the same problem,
At the same time I check relay #28 and #29 in fuse box under hood, they are ok.
I know voyage should be the same between B+ and Ignition 1, but it is bit hard to check.
I am wondering what it could be else ?
Does somebody have an idea ?
Saturn ION 2007
75,000 miles
2.2 echotech
Add to ticla's Reputation
Rate the quality of this post and help ticla reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ticla is offline   Reply With Quote
HELP!!!! 2009 Saturn Aura...P0685 & P1682 donrob42 Aura General 1 12-15-2018 12:22 PM
2002 SL2 Ignition Key hard to remove from Ignition when in Park floridasl22002 S-Series General 2 05-24-2018 08:51 AM
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 04:30 PM
08 Vue Code P1682 acdc 2008 Vue 6 08-02-2012 04:20 PM
Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission infinitezero Ion Tech 5 11-25-2011 05:47 PM
