Old 12-28-2019, 10:25 PM   #1
454cid
Default What is bouncing around inside my headlight?
I was looking at my headlights tonight because of how sun damaged they are, and I noticed something siting inside the driver's side.... any idea what it could be? I tapped on the light and the thing moved... definitely not attached to anything any more.
1999 Chevy K3500
Add to 454cid's Reputation
Old 12-28-2019, 11:06 PM   #2
toggenburg
toggenburg's Avatar
Default Re: What is bouncing around inside my headlight?
Time to replace the headlight assemblies.
You'll be glad you did, and your lights will enable you to see the road a whole lot better.
Old 12-28-2019, 11:17 PM   #3
454cid
I've been thinking about it.... almost ordered some a few times. I was also thinking about polishing the originals, but something loose inside can't be good.
1999 Chevy K3500
Old 12-29-2019, 01:53 AM   #4
98_Gold_Uranus
98_Gold_Uranus's Avatar
Yep, time to replace them. Looks like they're just breaking apart from the inside out. Some headlights have a shield that is in side the housing that goes over the bulb, I've seen those break loose before inside a headlight, but the 2nd gen S series do not have those so it's not that.
You can sand and buff them to get the lens clear again, but that's going to take the clear coat off and they'll only stay looking clear again for 5 or 6 months before the sun takes it's toll on them and they start getting hazy again...
I sanded and buffed the crap out of mine a little while back lol. They look amazing now, but they won't for long, and I'm well aware of that. But I'm in the process of trying to retrofit some 3rd gen SL lights that I going to throw some HID projectors into
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-29-2019, 03:21 AM   #5
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Originally Posted by 98_Gold_Uranus View Post
...You can sand and buff them to get the lens clear again, but that's going to take the clear coat off and they'll only stay looking clear again for 5 or 6 months before the sun takes it's toll on them and they start getting hazy again...
Look into using a few coats of Spraymax 2K Clear Coat on newly sanded and restored headlights. A high gloss, clear coat, semi-matte and matte version of this spray are available. I bought the clear coat to use on my new headlights.
https://www.amazon.com/U-S-Chemical-...ef_=ast_bbp_dp
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-29-2019, 10:41 AM   #6
3rd gens have the shade over the low beam, I believe everything except the SC and '93-'96 SC2 should have it too as I'm pretty sure it's legally mandated. Likely makes the low beams seem a bit better but on-comers probably hate you almost as much as those jackwagons with poorly installed HID kits.
No point in cleaning the outside when the inside is so bad and brand new ones are so cheap
Old 12-29-2019, 02:40 PM   #7
454cid
I didn't realize they were different between the generations. The 2K clear makes the polishing last a lot longer, I've been told.
1999 Chevy K3500
Old 12-29-2019, 02:46 PM   #8
454cid
My lights are dim enough that I doubt anyone cares. I wondered of it might be a cover, as you mentioned.
My concern is that I hear that the non-OEM replacements are often sub-standard in quality...usually in regards to the replacements for my truck, but I'd assume that goes for many lights given how cheaply they're sold for. I'll still probably get a set.
1999 Chevy K3500
Dirt/dust inside headlight romanster Astra General 9 08-19-2011 02:40 PM
New SC owner and water inside of the headlight, how do I fix it? artiksilver S-Series General 47 04-01-2011 08:15 PM
Popup headlight owners: sealed beam -> H4 conversion inside Viperoni S-Series General 3 08-26-2005 06:27 PM
SOHC Ram-Air Headlight?!? Idea...Pic inside ProjectSW1 S-Series Mods 16 02-26-2005 12:51 AM
cleaning inside the headlight lenses ENTP S-Series General 2 06-14-2004 05:44 AM
