Old 08-25-2014, 04:19 AM   #41
whitesl2much
whitesl2much has a spectacular aura aboutwhitesl2much has a spectacular aura aboutwhitesl2much has a spectacular aura about
Question Re: "S" Series RKE Remote and Option Programing
looked under my trunk carpet on spare tire board and saw I have the AUO option which means it should have Remote Keyless entry, correct?
I read everything here and it seems there should be some sort of module present? where exactly would I find that? which panel do I pull? Just want to make sure the module is present before I go spending money on a couple of key fobs.
98 SL2 with power windows, locks, etc.
thanks in advance for any responses, sorry for bringing up an old thread, but I feel lazy starting a new one with so much great info in this one.... still learning the etiquette and procedures of the forum so you can be straight with me.
Add to whitesl2much's Reputation
Rate the quality of this post and help whitesl2much reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whitesl2much is offline   Reply With Quote
Old 12-04-2014, 12:33 AM   #42
whitesl2much
Default Re: "S" Series RKE Remote and Option Programing
I ordered a FOB anyway and it works like a dream.
A couple months ago I think I found the module while replacing rear speakers.
it was on the side of the back seat. cant recall which side,
but it was a box with wires that my sl2 with no power locks does not have on it. hope this helps anyone who reads through these forums as much as I do.
Old 12-04-2014, 11:30 AM   #43
David 93 SL2m
David 93 SL2m's Avatar
2007 ION-3 Sedan
Happy Re: "S" Series RKE Remote and Option Programing
The module is on the passenger side.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
Old 02-07-2015, 10:22 PM   #44
JamTrip
JamTrip is on a distinguished road
Hello everyone!
I just programmed a remote I got on eBay today on a 1998 Saturn SW2 (wagon).
1996-1999 Saturn S-Series 4-button Remote ABO1502T
On the back of the remote reads:
GM 16207901-5
Canada 218101368
Model/FCC ID: ABO1502T
This is exactly what I did in this order.
Got in car. Did not even shut the door or lock or unlock the doors.
Put key in ignition to on (the position that gives power to the radio not the one that lights the panel behind steering wheel).
Used paperclip and jumped 4 and 8. (Top row of diagnostic connector found under the hood release on the drivers side).
000X000X
00000000 - X Marks the spot :-)
Held down lock and unlock on remote until horn beeped once.
Released buttons
Removed jumper from 4 and 8.
Held down lock and unlock on remote until horn started beeping, doors cycled and interior light was flashing.
Released buttons.
Turned off ignition, removed keys and tested remote.
Worked first time.
Hope that helps someone if having trouble.
Regards,
JamTrip
Add to JamTrip's Reputation
Rate the quality of this post and help JamTrip reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JamTrip is offline   Reply With Quote
Old 10-03-2015, 08:43 PM   #45
goldsaturn
goldsaturn is on a distinguished road
For anyone who is visual like me, this is the best video I could find showing exactly how to do everything talked about. After watching a YouTube video, it became crystal clear to me and that fixed an issue I was having.
It's a YouTube video that ends with this string:
ac_lSBVXloQ
Title: Programming RKE Module
Username: richpin06a
Uploaded: Uploaded on Dec 2, 2008
Programming Saturn RKE Module Not for Gen 3 (00-02)
Also, unlike what I've read in other posts in this thread, to program both of my rke fobs, I programmed both at the same time. I kept having issues doing one after the other but doing both at the exact same time worked!
Add to goldsaturn's Reputation
Rate the quality of this post and help goldsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goldsaturn is offline   Reply With Quote
Old 03-03-2018, 09:12 PM   #46
Ohdub
Ohdub is on a distinguished road
I am trying to program two additional remotes.
I have gone through all of these steps and cannot get my 1999 Saturn SL1 to go into programming mode. After jumping pins 4 and 8, the horn chirps once, but with the key in the LOCK position, I cannot get the remotes to program. I'm certain it's not in programming mode because the remote I do have continues to work and it does not get cleared out.
I have tried pressing the lock and unlock buttons simultaneously on the new remotes immediately after jumping the pins but that didn't work. I waited 30 seconds, tried again, and it still didn't work.
I tried turning ignition on and back to lock 4 times. Nothing happens, no lock/unlock, no horn chirp, nothing.
I remove the jumper and the old remote continues to work.
Add to Ohdub's Reputation
Rate the quality of this post and help Ohdub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ohdub is offline   Reply With Quote
Old 06-29-2019, 12:59 AM   #47
raridenour
raridenour is on a distinguished road
My locks do not cycle when I jumper the pins or when I program.. However the light on the interior flashes. Power locks work on both sides of car. checked fuses. Just cannot get fob to accept programming, any ideas?
1998 saturn sl2
Add to raridenour's Reputation
Rate the quality of this post and help raridenour reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raridenour is offline   Reply With Quote
What is option "Advanced audio system" ? ronnald Vue General 3 04-25-2007 10:24 PM
"Remote Trunk Release?" Chuckster Vue General 5 09-29-2005 07:19 AM
Possible "Easy" Fix for S-Series Gas Guage that Reads too Low wolfman How-To Library 14 08-30-2005 09:25 PM
Just used "30 day/1500 mile Exchange option" warren38 Vue General 2 03-18-2004 09:04 AM
"L" series owners: Seeking the "LOW" life? Abe95SC2 Mods and Performance 8 02-04-2002 11:19 AM
