Old 07-18-2014, 08:18 AM   #1
ALStensby
ALStensby is on a distinguished road
Default So...someone snuck a Supercharge on my SL1.
At least that's what it sounds like! Ha! I have an '01 Saturn SL1 5-spd with 132K on it.
Anyhow, there is a bit of a "whine" that accompanies the rise and fall of my RPMs. It's not super loud, but it is audible and seems out of the norm. I was thinking maybe the idler pulley, but that sounds a lot worse if I recall right. Any thoughts on where to start looking? Belt is in good shape. AC works fine. No sound when turning so it's not the PS I'd assume. Thanks in advance.
Adam L Stensby
2001 Saturn SL1
Add to ALStensby's Reputation
Rate the quality of this post and help ALStensby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ALStensby is offline   Reply With Quote
Old 07-18-2014, 08:42 AM   #2
the_wall
the_wall is on a distinguished road
1995 SL2
1998 SL1
Default Re: So...someone snuck a Supercharge on my SL1.
Alternator?
Add to the_wall's Reputation
Rate the quality of this post and help the_wall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_wall is offline   Reply With Quote
Old 07-18-2014, 08:53 AM   #3
Project84
Project84 will become famous soon enough
Project84's Avatar
2009 AURA XR
If it's not audible during raising RPM's in neutral, and ONLY audible while driving the car - throw out bearing is going bad or your transmission is low on fluid or the fluid is in need of replacing.
John
'09 Saturn Aura XR 2.4L
Previous - '01 SL1 daily driver and '96 SL2 auto 40+mpg hypermiler.
Add to Project84's Reputation
Rate the quality of this post and help Project84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Project84 is offline   Reply With Quote
Old 07-18-2014, 09:02 AM   #4
billysvue
2005 VUE 2.2L
Or the timing chain is going bye bye- all depends on where the noise is coming from.
POP the hood and tell use where on the engine the noise comes from. Garden hose stethescope works good enough.....
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 07-18-2014, 09:10 AM   #5
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
If you can post a video of the noise for us to hear that would help us better diagnose the problem.
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-18-2014, 11:48 AM   #6
shane22595
shane22595 is on a distinguished road
My car has just startd to make a whining noise as well! Started the day after I got the transmission fluid flushed and a new filter put in. It is not low on fluid, and I can only get the noise to occur while in gear accelerating anywhere from 2-3k rpm. The noise doesn't occur in neutral while revving the engine at all. I am stumped on this one. The belt seems to be fine from what I can tell as well.
Add to shane22595's Reputation
Rate the quality of this post and help shane22595 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shane22595 is offline   Reply With Quote
Old 07-18-2014, 12:26 PM   #7
Power steering pump likes to whine. Some times it's cold, sometimes it's low on fluid, sometimes it's just depressed...but whatever the cause it whines
Old 07-18-2014, 03:05 PM   #8
Signmaster
Just about anything with a bearing can whine like that. PS, alternator, idler, AC. I don't recall hearing a water pump get like that.
With a screwdriver or mechanic stethoscope you can probably narrow it down. A section of PCV or similar tube will often work too, even rolled up poster board or something.
If you are fairly certain on the noise, you will likely find excess heat and the source of the problem.
Old 07-19-2014, 11:27 AM   #9
ALStensby
I'll have to try and dig in to it a bit this week it sounds like. I'll check all of the items suggested. Thanks!
Adam L Stensby
2001 Saturn SL1
Old 07-21-2014, 10:55 PM   #10
jfug97
jfug97 is on a distinguished road
If you figure it out let us know, mine is making a similar noise.
Add to jfug97's Reputation
Rate the quality of this post and help jfug97 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jfug97 is offline   Reply With Quote
Supercharge '99 SC2 saleenman S-Series Mods 10 12-30-2012 10:16 PM
can i supercharge JohnnySL S-Series Mods 11 07-23-2008 04:43 PM
Supercharge? TrainerL200 L-Series General 21 09-09-2007 08:47 AM
supercharge? defy69 Ion Mods 40 02-17-2006 12:18 AM
Supercharge?Help. 97SCa-spec Mods and Performance 24 10-26-2003 02:44 PM
