Old 12-26-2013, 01:57 AM   #21
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Default Re: short term fuel trim
Agreed, However any engine with over 200K on it will have natural wear on internal components, Compression rings included.
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-26-2013, 02:07 AM   #22
dakota1820
dakota1820 will become famous soon enough
Its the 02 and has 123,000 miles
Add to dakota1820's Reputation
Rate the quality of this post and help dakota1820 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dakota1820 is offline   Reply With Quote
Old 12-26-2013, 02:09 AM   #23
anmasher
anmasher has a spectacular aura aboutanmasher has a spectacular aura aboutanmasher has a spectacular aura about
anmasher's Avatar
1996 SL2
Sure, but the PCV-Blowby-oil consumption connection is a bit of a stretch.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
anmasher is offline   Reply With Quote
Old 01-02-2014, 02:38 AM   #24
1996SL11.9L
1996SL11.9L has a spectacular aura about1996SL11.9L has a spectacular aura about
1996SL11.9L's Avatar
2002 SL1
When I swapped heads the amount of carbon on the pistons and stuck to the combustion chamber could have easily raised the cranking pressure above 200. I had major detonation problems too.
I always go by the LTFT to determine the health of the system...Assuming my O2 sensor is working properly. Its the final correction. When The short term maxes out trying to trim fuel it increases or decreases the LTFT by 1 and rezeros the STFT and starts over.
I have the ScanGauge on my Satty and programmed the AFR PID. It starts cold shooting for a 8.0 AFR. As it warms up it slowly goes to 12.0 by 120 degrees. around 160 degrees its up to 14.2 AFR. and as OldNuc says somewhere between 170 and 195 it will switch to 14.7 AFR. which it considers fully warmed up......
I have not correlated anything to why it shoots for 14.7 at 170 degrees ECT and the next time I'm driving it will wait to hit 192 before it changes to 14.7 AFR.
WOT is calling for 12.3 AFR.
Around 5 or so years ago I found a great write up on how to use the LTFT to troubleshoot fuel injection problems......Never found it again.......or I wold have kept the PDF.
Add to 1996SL11.9L's Reputation
Rate the quality of this post and help 1996SL11.9L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SL11.9L is offline   Reply With Quote
Old 01-02-2014, 10:30 AM   #25
The A/F ratio from the fuel map programmed into the PCM considers several parameters and coolant temp is only 1 of many.
Old 01-03-2014, 01:40 AM   #26
1996SL11.9L
2002 SL1
I agree...........it's just interesting and thought provoking to know what it takes for the PCM to select 14.7 to 1 sometimes, I drive 10 miles before I get to 14.7. other times I'm driving along at 185 or so and its 14.2.....then I lift off the gas to coast a bit and get back on the throttle and it 14.7...........temp never changed.
Old 01-03-2014, 09:40 AM   #27
Yes, it is interesting to collect this data but some people will grab those numbers and then insist that at 1 degree less than 170 the system will not be fully warmed up. I have already seen this happen repeatedly.
How many times have you seen it said on here that he system does not enter closed loop until some specific temp value is reached or you are in open loop until 14.7:1 A/F is reached?
The system goes to closed loop as soon as the O2 sensor output signal commences switching(<300mv, >600mv), nominally requires a 600F tip temperature which is reached in seconds after starting the car.
Old 01-03-2014, 04:11 PM   #28
ehunter
ehunter has a spectacular aura aboutehunter has a spectacular aura about
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
1996 SL2
You can chase this issue for quite a long time and never find why your idle has the occasional hic-ups. My car used to do the same thing and I never quite pinpointed why. Possibilities are:
1) O2 sensor does not switch fast enough. I had a Bosch sensor that switched from high to low and back every 1.5 seconds. I can see how the inaccuracies of a slow sensor might periodically cause a hic-up. The Denso I have now switches much less than 1 second.
2) Vacuum leak causing the O2 sensor to periodically fuel starve the motor. The leak can be anywhere.
3) Fuel filter becoming clogged.
Note: the ST and LT information that has been posted up I see little value to. The numbers are just snapshots that change wildly and very quickly so you really cant deduce anything from them. Even the LT values can be inconsistent from starting and stopping the engine for a re-measurement. The LTs are relative measurements that may not be repeatable from one engine start time to another. The LTs are fuel delivery stair-step-ups or step-downs when the ST corrections fall out of min/max boundaries. But in general, the LTs should be fairly stable in a controlled driveway idle.
If you want to be able to utilize the ST/LT information in a more meaningful way, you will have to watch the behavior, data point by data point. (tenths of a second apart is best) Your goal is to validate the average of all STs is zero with a controlled idle in the driveway. Trying to do this while driving introduces too many moving influences.
Most likely your ST average is going to be negative (running rich). Not often is it too lean. Can you say what your fuel economy is at this point with new plugs and wires?
So in summary, make sure you have a good quality O2 (Denso/NGK) and start looking for vacuum leaks. Also you should be able to validate your old PCV runs with the same results to rule out the fixed orifice is not an issue.
The fixed PCV helps to adjust the crankcase pressure to either lower or higher pressures. If it brings the pressure down, less oil can get pushed out of the engine(leakage). If higher pressure is created, more leakage can occur.
Add to ehunter's Reputation
Rate the quality of this post and help ehunter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ehunter is offline   Reply With Quote
Old 01-29-2018, 05:24 AM   #29
Bob8732
Bob8732 is on a distinguished road
In my opinion the brand is very cool and produces the best devices! Thank you for posting. All the best.
Add to Bob8732's Reputation
Rate the quality of this post and help Bob8732 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bob8732 is offline   Reply With Quote
Short Term Fuel trim -20 to -35 until ~160degF, normal? ssewall S-Series Tech 35 10-24-2011 10:06 PM
Reset LTFT (Long Term Fuel Trim) td1238 S-Series Tech 6 07-07-2011 09:49 PM
Long Term Fuel Trim 1996SL11.9L S-Series Tech 31 03-09-2010 04:34 PM
long term fuel trim at idle---95 SC2 derf S-Series Tech 24 02-04-2010 08:56 AM
Neat way to get car for short term - SC2 piney S-Series General 1 01-17-2002 04:31 PM
