Old 03-24-2006, 10:22 AM   #1
Luke
Luke's Avatar
Default Additional TAM requirements when replacing any of its four components
When changing any of the four components of the TAM (((>Torque Axis Mount<))) the following should be stressed.
Attached and supporting the Engine Strut, often overlooked, is a bracket in which one end of the strut sits. This bracket, upon close examination, is afixed to the engine cradle. However, it is attached with two bolts/fasteners. The nuts can be reached only from underneath the cradle.
These two nuts, should be loosened after any work is done on any of the TAM's four components. Therefore, after replacing either the (upper) Engine Mount, the (lower) Transmission Mount, the Transmission Strut, and/or the Strut-to-Engine, it is important to loosen these two nuts/fasterns and then re-torquing (Spell ?)them .
This effort accomplishes the removal any "fore/aft preload" from the Engine Strut.
Torque = 37 ft lbs.
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline   Reply With Quote
Old 03-24-2006, 06:24 PM   #2
madpogue
1996 SW2
Default Re: Additional TAM requirements when replacing any of its four components
Good timing! I've done all my TAMs, except for the engine strut ('99 dogbone coming soon, which will receive Prothanes). I'll have to remember this little nugget when it comes time to install.
Add to madpogue's Reputation
Old 03-24-2006, 06:45 PM   #3
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
What does this mean when it comes to changing the upper mount?
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 03-25-2006, 02:50 PM   #4
flyhop
flyhop is on a distinguished road
2000 SL2
Anybody got a picture of the aforementioned "engine strut" as I am going to replace the top engine mount (TAM) tomorrow? Thanks.
Add to flyhop's Reputation
Rate the quality of this post and help flyhop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyhop is offline   Reply With Quote
Old 07-12-2006, 04:19 PM   #5
Bob K
Bob K has a spectacular aura aboutBob K has a spectacular aura about
Anyone dig up a picture yet of the aforementioned bracket?
Add to Bob K's Reputation
Rate the quality of this post and help Bob K reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bob K is offline   Reply With Quote
Old 07-24-2006, 06:43 PM   #6
madpogue
1996 SW2
Dang, I thought I'd posted on this thread a while ago. I scanned the FSM page on this, and took a pic of the nuts that need to be re-torqued.
FSM Page:
http://www.saturnfans.com/photos/sho...p/photo/30459/
View from below of the two nuts:
http://www.saturnfans.com/photos/sho...p/photo/30458/
Old 04-26-2007, 02:46 PM   #7
madpogue
1996 SW2
The photos section is down at present, but the files themselves still seem to be there, so here are the photos "stand-alone":
FSM Page: http://www.saturnfans.com/photos/data/500/mountfsm.jpg
View from below of the two nuts: http://www.saturnfans.com/photos/data/500/mountnuts.jpg
For "perspective", that view is straight up. "Bottom" of the frame is the front of the car. Right side of the frame is the right side of the car. Diagonal member in lower right is the sway bar. Upper right is the passenger-side driveshaft.
Old 04-26-2007, 06:27 PM   #8
padibona
padibona is on a distinguished road
Does that mean at any time (even like 6 months) we can (should) loosen these nuts and re-tighten?
Add to padibona's Reputation
Rate the quality of this post and help padibona reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
padibona is offline   Reply With Quote
Old 04-27-2007, 03:27 PM   #9
madpogue
1996 SW2
I don't see why you couldn't, at any time. And if you missed it the last time you worked on the mounts, and you're getting any vibration or the like, it's worth doing.
Old 05-07-2007, 05:16 PM   #10
Phredawgy
Phredawgy is on a distinguished road
Phredawgy's Avatar
1996 SL2
Yes...as madpogue added it is worth doing if you missed it when you initially did the work...I didn't see this part of the How to section until I installed the new mount.......and it cured a big vibration I was getting....
The streets will flow with the blood of all the non-believers!!!! And all those who won't include their vehicles vital information in their posts!!!!
Add to Phredawgy's Reputation
Rate the quality of this post and help Phredawgy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phredawgy is offline   Reply With Quote
Torque Axis Mount's (TAM) Components Luke How-To Library 0 03-31-2006 11:12 AM
Opinions: Window Weld TAM vs OEM TAM Red97sc2 S-Series Tech 3 02-26-2006 07:55 PM
Finally getting around to replacing TAM... PitchBlackSC2 S-Series Tech 2 09-19-2005 03:57 PM
What requirements do you have to have to work at Saturn? cdp326 General Saturn Discussion 43 09-05-2004 12:53 PM
L-series maintenance requirements HELP! Yankeez01L30094SL2 L-Series General 19 03-17-2001 12:20 PM
